An easier way to refuel your tractor
   / An easier way to refuel your tractor #61
Only thing I have diesel is tractor and it holds 8.6 gal if I remember correctly won't quite take 2 full 5 gallon cans so this pump works great for me, I just can on ground next to tractor set pump on top next to filler put line in can and tank hook power to tractor and turn it on
   / An easier way to refuel your tractor #62
Just checked tractor holds 8 gal what I like about the pump I have is where ever I have tractor it's easy to bring pump and 5 gal can to tractor. next time I fuel it up will try to get video.
   / An easier way to refuel your tractor #63
I dont know seem so if you can get the 5 gal jug on the tractor you got it made, that pump should be able to pump from the ground. He's like me when I first got my tractor, put a rag on the hood so I wont scratch the paint, those days are long gone.....................
EASY Way to Pump Fuel into TRACTOR ~~ Kubota L251 - YouTube
   / An easier way to refuel your tractor #64
Top of my tractor where fill is probably about 5 ft maybe little more my pump will pump it up to tank with can sitting on the ground, which is a good thing for my metal knees
   / An easier way to refuel your tractor #65
Got to love my Massey, fuel filler just ahead of the step. Engineers did that one right.
   / An easier way to refuel your tractor #66
If you are stuck using normal 5 gallon jugs with the typical safety spouts that take forever to dispense 5 gallons there is a cheap and easy trick to help it breath and flow better. Get a tire valve stem for a tubeless tire and remove the guts from it. Drill a hole and install the valve in the back side of the jug where the vents use to be. Remove the valve stem cap to let it breath and flow better when filling up. It took mine from about 6 minutes to 2 minutes to empty a 5 gallon jug.
How to install a vent in a plastic gas can - YouTube
   / An easier way to refuel your tractor #67
Using my pump I can just take the cap off of can
   / An easier way to refuel your tractor #68
Using my rattle hose I can drain a can without standing there holding it up, or worrying about spillage. I try not to let the tank get below half, so 5 gallons brings it back to the top.
   / An easier way to refuel your tractor #69
55 gallon barrel with a handcrank barrel pump and a piece of hose. No lifting cans anywhere. No power source needed. Get red tinted fuel at 'off-road' prices.
   / An easier way to refuel your tractor #70
From truck bed to bucket, raise bucket.
WOODS BRUSHBULL XTREME BB840X 7' ROTARY MOWER (A57192)
WOODS BRUSHBULL...
2011 BMW 750Li (A55973)
2011 BMW 750Li...
Volvo L70G (A53317)
Volvo L70G (A53317)
48in Pallet Fork and Frame Skid Steer Attachment (A55851)
48in Pallet Fork...
2013 Ford F-150 (A53422)
2013 Ford F-150...
2010 John Deere TX Gator 4x4 Utility Cart (A55973)
2010 John Deere TX...
