Amsoil synthetic fluids in a 2520 anyone?
   / Amsoil synthetic fluids in a 2520 anyone? #1
barry1me
SE MI
JD 2520
Guys I have 177 hours on my used 09 2520 that I just purchased. Original owner used all JD fluids and Filters. I was going to change oil/filter, HST , and front axle fluid. I have ran Amsoil synthetics in a lot of other things and had good results. What is everyones thoughts about running amsoil in there tractors?
   / Amsoil synthetic fluids in a 2520 anyone? #2
I have been using Amsoil in my JD compact tractors for years without any problems.
   / Amsoil synthetic fluids in a 2520 anyone? #3
I run Amsoil in all my vehicles and farm equipment.
   / Amsoil synthetic fluids in a 2520 anyone? #4
Cool, it looks like you got it! I don't think you will be disappointed with it. I love mine and can't believe how much a tractor of this size will do.
   / Amsoil synthetic fluids in a 2520 anyone? #5
If you don't mind the additional expense, Amsoil should work just fine. Just make sure you use the right viscosity for the right application. HyGard and HyGard Lo-Vis are of a different viscosity for example. Since your engine is EPA Tier III, their 15W40 is fine for the engine. If your manual says J20D for the HST, go with their PowerShift 10W transmission fluid. If it calls for J20C, go with the 30W. Not sure about yours, but my 2011 3720 HST front axle takes the same J20D as does the transmission/rear diff. Grease, filters, etc should be self-explanatory. But I'd be surprised if you could get a HST filter from Amsoil.
I don't put many hours on mine, so change fluids by the calendar rather than by the hour meter. As such, I stick with the less expensive conventional lubricants.
//greg//
   / Amsoil synthetic fluids in a 2520 anyone? #6
Hi chevy,
Can you tell me what you are using for fluids in your jd2720?
   / Amsoil synthetic fluids in a 2520 anyone? #7
I run the Amsoil ATH in my 2210 hydraulic system, have been since the first change, it meets both J20C and J20D specs and works great in all temps:
PRODUCT DESCRIPTION
AMSOIL Synthetic Tractor Hydraulic/Transmission Oil is an all-weather Universal Tractor Transmission Oil (UTTO) engineered to meet the tough demands of heavy-duty, hydraulic-powered farm and commercial equipment. Its unique formulation of synthetic base stocks and additives effectively reduces wear, resists heat, protects against rust and extends fluid and equipment service life. Synthetic Tractor Hydraulic/Transmission Oil is recommended for extended oil drains based on oil analysis.
Excellent Protection in Temperature Extremes
AMSOIL Synthetic Tractor Hydraulic/Transmission Oil operates over a wide range of temperatures. It has a high viscosity index to maintain its lubricity for wear protection at high operating temperatures, and it flows at temperatures down to -58°F (-50°C) for improved equipment operation at low temperatures. Synthetic Tractor Hydraulic/Transmission Oil exceeds the viscosity requirements of the all-weather specifications of both Case New Holland 3525 and 3526 (formerly Ford New Holland FNHA-2-C-200 & 2-C-201) and John Deere J20C & J20D, helping eliminate the need for seasonal oil changes.
Smooth Brake Operation
AMSOIL Synthetic Tractor Hydraulic/Transmission Oil is formulated with durable friction-modifier additives that effectively suppress wet-brake chatter. Unlike lower-quality oils that can break down and cause vibration, AMSOIL Synthetic Tractor Hydraulic/Transmission Oil provides continuous frictional stability for long-term smooth brake operation.
For the front axle and engine I use Mobil 1 products, again with great results.
   / Amsoil synthetic fluids in a 2520 anyone? #8
Wow. $37/gallon for that ATH. I like my John Deere. But not enough to spend nearly $300 on transmission fluid !!
//greg//
   / Amsoil synthetic fluids in a 2520 anyone? #9
Personally I think Amsoil is a bit over priced for its protection capabilities. There are better oils that are cheaper especially if you compare cost/performance.
2006 V.E. ENTERPRISES 130BBL TANKER (A53843)
2006 V.E...
2006 Toyota Tundra 4X4 Pickup Truck (A53422)
2006 Toyota Tundra...
2017 FORD F550 XL BUCKET TRUCK (A51406)
2017 FORD F550 XL...
43030 (A51691)
43030 (A51691)
2021 JOHN DEERE 524P WHEEL LOADER (A52705)
2021 JOHN DEERE...
2014 Ford F-150 4X4 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
