Amsoil HD 5W40?
   / Amsoil HD 5W40? #3
From what I've read on the truck forums, it's a good oil, just expensive. Everytime I've run across it in a store, it's almost twice as high as T6.
   / Amsoil HD 5W40? #4
My opinion? If Amsoil HD 5W40 meets or exceeds the Specs. for your application, use it. Although Rotella T6 5W40 appears to be a quite popular among the forum members here, it is not the only good oil on the market.
I think the preference of Rotella T6 brand 5W40 synthetic oil has to do with price and the readily availability almost any where.
   / Amsoil HD 5W40? #5
If you are looking at doing extended oil changes and using the Amsoil Ea filters, it is great. If you are going to use standard drain intervals, there is not much point. Amsoil is a high TBN oil made to support extended drain intervals on mechanically sound engines. It is one of the best oil packages you can buy. But I don't see the point in it if your going to drain a high TBN oil out and throw it away at 7,000 miles when it really will go 25,000 miles with ease.
I do use Amsoil, and I do use the Ea filter and pull a Blackstone sample every spring. My last oil change on the Powerstroke was after 4 years running, it tested acceptable by Blackstone yet, but was getting low in the TBN finally. I just change the filter every spring and top off now and again with the same Amsoil. I also run Amsoil in my UTV, air cooled garden tractors, air cooled push mowers and log splitter. I do not do oil changes more than once a season in the air cooled engines.
Good stuff, but if following a manufactures oil change interval, I would just buy what is cheap and change it as specified. Since I hate changing oil.... call me lazy... I go Amsoil and minimize that task.
   / Amsoil HD 5W40? #6
I use Amsoil in all my stuff, have it delivered direct. I would have to agree, doing an oil analysis is the best way to define your own needs. I prefer Wix filters and change them at the halfway point (if oil is 20000, new filter and top off at 10000). Our Honda Ridgeline has an oil percent usage indicator that the dealer people swear its the way to decide change interval. But it has turned to 0 at 7500 miles twice now, pretty sure the magic percent indicator is mileage based not usage.
   / Amsoil HD 5W40? #7
"But it has turned to 0 at 7500 miles twice now, pretty sure the magic percent indicator is mileage based not usage."
Those systems do not know the oil life remaining of a high TBN synthetic, it's a pure math based algorithm assuming the standard recommended oil and filter in a mechanically sound engine.
When you decide to buy into the Amsoil high TBN synthetic oil and extended drain internals you pretty much have no choice but to rely on oil samples to tell you the truth.
If your putting 25,000 miles a year on your engine, I would say to buy the Amsoil filter and 25K rated 12 or 14 TBN oil and just change it at 25K. If like us, your putting 5K to 7K miles a year, but the same and do the $30 oil sample each year and run it until the oil is showing signs of needing replaced. In my case it's many years. The Powerstroke is stored in a heated garage and typically used when needed, but not as a daily grocery cruiser, so it may not move for weeks at a time.
   / Amsoil HD 5W40? #8
I like the Amsoil stuff, use it in everything now. The pick-up and dump truck get yearly changes (btw - they recommend 25K miles or annually on signature series), and I use OE in my daily driver for stock 10K mile changes.
I was never an Amsoil fan due to availability. My preference has turned because I can now order online and get it in a few days. I keep it on hand (as well as ATF and grease) so I never need to blend it. And with dealer or preferred customer pricing, its competitive with any other synthetic (minus fire sale stuff).
   / Amsoil HD 5W40?
This is going in the MF1635 which gets changed annually. T6 is $51/5L jug while I can get the Amsoil for less.
Rotella prices keep going up, I figure its time for a new flavour.
Thanks.
   / Amsoil HD 5W40? #10
I use to sell amsoil many years ago (direct selling) and will say it is great oil, really love the grease. I stopped using it because its just not worth it to me. There has been no motor failures due to oil in many years, they only fail due to lack of maintenance. So if your willing to buy into the parts and analysis then you can extend the oil changes for a long time. I just as soon buy oil which meets manufactures specifications and change it as necessary. Works for me
Still like to use the grease in my boat trailer hubs do to it does not absorb water
2019 Chevrolet Tahoe LT SUV (A51694)
2019 Chevrolet...
Ex Mark Zero Turn Mower (A51573)
Ex Mark Zero Turn...
Hitachi Zaxis 350 LC (A51573)
Hitachi Zaxis 350...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A53472)
JOHN DEERE ROW...
City of Buckhannon - 2000 Chevy 2500 (A52384)
City of Buckhannon...
LMC LOT NUMBER 144 (A53084)
LMC LOT NUMBER 144...
