AMSOIL Does Not Meet Super-UDT or M2C200
Status
Not open for further replies.
   / AMSOIL Does Not Meet Super-UDT or M2C200 #31
Will using it be ok with the Kubota warranty ?
   / AMSOIL Does Not Meet Super-UDT or M2C200 #32
Yes, you can use it in any UDT or super UDT. People are making an issue out of Super UDT when the specifications of Super UDT go over and above Hyd fluids. If you want, email Amosil so you can make a copy of somthing.
When I talked to Ed about the respsonce to the question post on TBN, he said that it was correct but they is more to it.
The way they explained it was that Super UDT is a dual-purpose fluid as Darryn and Ed said. It is just the UDT specis for hyd only and Super UDT is for a multi-purpose fluids (more then hyd fluids apps). The difference between UDT and Super UDT has nothing to do with the quality of the lubricant as stated.
And you can use one their fluid in any palce calling for UDT or Super since Amsoil fluids far exceeds Super UDT requirements.
   / AMSOIL Does Not Meet Super-UDT or M2C200 #33
</font><font color="blue" class="small">( I know they do not have a litte "star" for API certification on most of their oils. They pass the spec and that is all the matters.
Their oils have higher ZDDP, which is good, and if going for a little star, their zddp would be low.
I just noted it was weird
)</font>
EC and ECII etc (starburst) certification (applies to spark ignited engines) is not relevant. My point is that Amsoil has very few oils that have any actual API certification (ex: CI-4) but they do RECOMMEND these oils for the application...
Status
GMC 2500HD 4wd Service Truck (A56438)
GMC 2500HD 4wd...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2018 HINO SA (A58214)
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
Informational Lot - Financing (A56438)
Informational Lot...
2020 Deere 544L (A60462)
2020 Deere 544L...
