Amsoil 20W50 hydrostatic transmission fluid in Cub Cadet gt 2544 tranny?
   / Amsoil 20W50 hydrostatic transmission fluid in Cub Cadet gt 2544 tranny? #1
Cub gt 2544=best
2007 Cub Cadet GT 2544
Will Amsoil 20W50 hydrostatic fluid work in the transmission of the 2500 series?
   / Amsoil 20W50 hydrostatic transmission fluid in Cub Cadet gt 2544 tranny? #2
Bet it's a whole lot heavier than what is there. Typically many transmission oils are only 10 to 20w.
Once put gear oil in the transmission of our car, as either it or ATF was allowed back then (1965). Thing could hardly be shifted. Removed the gear oil and put ATF in.
   / Amsoil 20W50 hydrostatic transmission fluid in Cub Cadet gt 2544 tranny? #3
Yes you can. I have been using Walmart branded 20-50 in my Gt2542 ever since I first changed it around 150 hours. It is now over 1000 hours and hydro seems as good as new. I don't know if information is still there but when I decided to change my fluid even though operators manual didn't say to, I found info on Hydro Gear site that said to use 20-50 conventional or syn. I have changed mine with conventional around every 100 hours.
   / Amsoil 20W50 hydrostatic transmission fluid in Cub Cadet gt 2544 tranny? #4
When I changed the fluid in my lawn mower (JD110) the recommended fill was 20W-50 synthetic.
   / Amsoil 20W50 hydrostatic transmission fluid in Cub Cadet gt 2544 tranny? #5
What do I use in my vehicles - whatever the OM recommends.
   / Amsoil 20W50 hydrostatic transmission fluid in Cub Cadet gt 2544 tranny? #6
We have used 15w40 for a lot of applications, I would think it will be fine.
After doing further research (and reading the bdu and 15/70 series manuals and specs). You can infact use 20w50 in the bdu10l and bdu21l incase anyone wanted to use the amsoil 20w50 hydrostatic fluid.
2000 Ford F-250 (A53314)
2000 Ford F-250...
Jumper Cables (A53316)
2016 Chevrolet Express Ambulance (A55788)
2016 Chevrolet...
2014 VOLVO A25G ARTICULATED DUMP TRUCK (A51406)
2014 VOLVO A25G...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55301)
UNVERFERTH 330 -...
2017 Ford F-250 Crew Cab Pickup Truck (A55788)
2017 Ford F-250...
