Ammo box additions
   / Ammo box additions #1
JLH4
Hobby Farm in Central Kentucky
Rural King - RK24
I needed a bigger toolbox and some way to carry chains on my RK24 so I added these two ammo boxes.
   / Ammo box additions #2
Like to see a pic on how box was mounted to ROP...
Have a box, just not sure where I want to mount it.... Some put them on FEL subframe...
dale
Put mine on the ROPS in the same place as the original one using the same hardware. For the chain box I bolted it in the hole where the trailer ball goes.
Joe
   / Ammo box additions #6
I keep my chains in a PCV pipe I mounted. The 50 cal ammo box I use for tools. I mounted mine on the inside of the ROPS. Chain holder.jpgIMG_20180708_160649.jpg
   / Ammo box additions #7
Make good tool boxes as they also keep dust and water out. Installed metal one and will be replacing with plastic possibly due to rust issue.
   / Ammo box additions #8
I added ammo box behind seat connected to ROPS...angle iron between ROPS post fasten ammo box.
   / Ammo box additions #9
I added a 40mm ammo box to the side of my L4330. It used to have a top, until some dumbsh$% put it on the rear tire temporarily and then forgot about when I drove, uh I mean when he drove off. :(
Best pic I have of it:
   / Ammo box additions #10
After poking around unde rear apron of my MF GC1715 I discovered a bracket with a couple of holes in it under apron... Hmmmm..... Some scrap aluminum from "resource pile", drill a few holes, some 5/16 bolts and nuts....
Next project is "slow vehicle sign" that rips the skin off my arm when ever I get too close....
Dale
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
1996 Ingersoll-Rand VR642C (A47477)
1996...
New JMR Mini Skidloader 40" Grapple (A50775)
New JMR Mini...
Pair 2 - ST225/75R15 radial trailer (A55787)
Pair 2 -...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A54814)
2016 Ford F-550...
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
