Am I throwing money away if I by this TSC box blade
   / Am I throwing money away if I by this TSC box blade #21
It’s a whole lot easier to add some bracing before bending. Pushing back buts the most stress and damage to the frame. A receiver hitch might be handy too.
   / Am I throwing money away if I by this TSC box blade #22
there isn't much to anything wearing out in box blades besides they get ugly when they rust. I bought a used one years ago for $500. It weighs 1000lbs plus so it doubles as a ballast. That one sells for 4K at least now. It is a world of difference when digging in. I know you bought one already but you can improve what you have if you need to.
   / Am I throwing money away if I by this TSC box blade #23
Though I agree that the average worker at the TSC stores aren't the most experienced or sometimes the brightest, I've alsways found them helpful. They'll check whatever they can for you if you ask.
Yes, I'd check for consistent welds and other construction flaws, but the average user should be OK with the County Line brand.
   / Am I throwing money away if I by this TSC box blade #24
This TSC box blade is only rated 32hp and my LS is 42hp. Would I just destroy it or could I just slice slower? Never used a box blade before.
This will be O.K. using in forward scraping but the weak link will be in reverse pushing with one corner doing most of work. With a box blade buy one that is over rated for your tractor. It will give you extra weight for a counter balance if you have a loader. The extra thickness of the metal will allow your tractir to spin it's wheels when pulling or pushing without bending your box blade.
I have a WorkMaster 50 New Holland (4x4) with a 8 ft. HD box blade. At the beginning I had one of those one piece quick hitch category 2 HD hooked to box blade. Pushing backwards in a thicket/brush one side of box blade hit a stump/rock twisting the hell out of the quick hitch but the box blade did not bend. Replaced the twisted one piece quick hitch with Pat's brand category hitch 2 and no problem since. Anything that doesn't move just causes the tractor to spin with no damage to Pat's quick hitch or box blade.
   / Am I throwing money away if I by this TSC box blade #25
Get one that is a few inches wider than your back tires so you can cover your tracks.
I have a Westward Branded, Chinese built one, works great.
   / Am I throwing money away if I by this TSC box blade #26
If it bogs the tractor down, raise it slightly!
   / Am I throwing money away if I by this TSC box blade #27
I imagine the manufacturer's rating is a generalization as to the weight and traction that the average 25-35 engine HP tractor has, and that's about it.
So if they'r saying 35hp max, and yours puts out 42, that's 20% more HP, so no warranty claims (is there a warranty?).
Absolutely. A generalization that people who 'have to ask' can look at so they don't buy things that their tractor literally can't pick up off the ground, etc. It's not a high quality bit of information.
I have a TSC 60" box blade. I've added weight to it, but it was working fine for my needs before that, now just cuts in a little quicker at the start of each pass.
I think you have to have a pretty serious size class mismatch going before you can snag a ripper on something and have the tractor, from a dead stop, just start tearing and bending metal instead of spinning tires. I think the main factor there is actually momentum. Kinetic energy goes up with the square of speed or something like that, basically if you go twice as fast you're carrying 4 times as much energy. So even a properly matched tractor and implement are still going to find and break the weakest link if you snag something while moving too fast. So I don't really buy the 42hp Kubota just ripping through the "35hp rated" box blade unless there was a rolling start involved.
There's no incentive for reviewers to be honest about how they broke their product, and besides...If all the buyers knew how to handle all the variables, then retailers wouldn't bother rating drag implements, with no driveline.. by HP! ;)
   / Am I throwing money away if I by this TSC box blade #28
My boss got a 6' Countyline box blade for our 4052r and I wish he'd spent a little more on a heavier duty one. We haven't used it much but two ripper teeth have broken off tips and the steel is tweaked on both sides near the lift arm pins. Comparing it to other brands it is kind of a weak design.
   / Am I throwing money away if I by this TSC box blade #29
I've got a Titan #3206. It's well built. 1/2" side plates. I wish it were heavier though. Weights 530 pounds and it's not enough. Sometimes it gets bouncy so I'm thinking of adding more weight. But otherwise it seems like a very sturdy unit. B.
   / Am I throwing money away if I by this TSC box blade #30
Bouncy ?? ?? How do you do that unless you are going as fast as the tractor will move full speed ??
On my cheap, China built box blade there are a number of places to hang 42# suit case weights..
2014 TAKEUCHI TB290 EXCAVATOR (A52707)
2014 TAKEUCHI...
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
2004 950M Towable Cement Mixer (A55851)
2004 950M Towable...
2015 Chevrolet Tahoe SUV (A55853)
2015 Chevrolet...
2008 Ford Fusion SE Sedan (A54815)
2008 Ford Fusion...
UNUSED FUTURE HL525 25" (A57193)
UNUSED FUTURE...
