Am I the Only One
   / Am I the Only One #1
Dingbat
Cedar Island NC (Outer Banks)
YM 1700
that cannot push diddly with a 1700 and a box blade /forums/images/graemlins/confused.gif? I can pull the blade up a storm put if I try to push dust, the wheels start spinning. I know, the tread direction favors pulling, but I mean, I can't push anything! Any hints?
   / Am I the Only One #2
I guess I only tried pulling when I owned a 1700. It was 2WD and I assume yours might be too. 4WD may have helped.
   / Am I the Only One #3
</font><font color="blue" class="small">( Any hints? )</font>
Possibly tilt the box blade forward a bit so the rear blade doesn't try to dig in quite so much.
   / Am I the Only One #4
Boxblades and 3ph's are not designed for pushing. If you push very much you will probably bend or break something. That rear blade is for dragging and smoothing.
   / Am I the Only One #5
I never was very handy at using the box blade. With my 1700 and a 5' straight blade I can pull and push with equal success.
   / Am I the Only One #6
</font><font color="blue" class="small">( if I try to push dust, the wheels start spinning )</font>
I think wheel weights or tire ballast is what's missing. I can pull a 90% full box with rippers down, or push 1/3 of that, with 450 lbs of water in the tires on essentially the same tractor.
   / Am I the Only One #7
I think angle of the blade and the amount of material you are targeting will be the issues.
I've cut nicely while pulling.. but when pushing I have to angle the blade back up a bit. Also.. I found I could push a pile while slowly lifting the blade, to kind of make a 'running ramp' to smooth stuff out backwards.
But a bulldozer it aint. I broke my adjustable link the first day I had the box blade /forums/images/graemlins/shocked.gif.. well first hour! So don't feel bad. That was before I had stabilizer chains to keep the box outta the tires.
Soundguy
   / Am I the Only One #8
I noticed that i couldn't push that well, so i had some fluid put in the tires. mine's 2wd , but if i square up and put the diff lock in, ipush pretty good. soundguy has some good advice,try to raise the stuff being pushed, and adjust your angle.
   / Am I the Only One
Thanks guys for the good hints and making me realize that it is not Operator Headspace as we say in the Army. It is not often that I would want to push but the few times that I did were frustrating. Steve
2023 John Deere 410R Sprayer (A53342)
2023 John Deere...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
SKYJACK SJIII 3226 ELECTRIC SCISSOR LIFT (A51246)
SKYJACK SJIII 3226...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
Kubota SVL95-2 High Flow Cab Skid Steer (A53472)
Kubota SVL95-2...
