Buying Advice Am I nuts? Thinking of leaving ZTR for SCUT?
   / Am I nuts? Thinking of leaving ZTR for SCUT? #51
I completely separate mowing lawns from tractoring. So I say keep the ZTR with that much lawn and try to work the tractor in long term.
   / Am I nuts? Thinking of leaving ZTR for SCUT? #52
Not necessarily. I cut 5-6 acres/week with my ZTR. It takes me roughly 2 hrs/week, for lets say 6 months out of the year, so 48 hours per year. Those hours will add up on either machine (if I use a ZTR or a tractor) but the hours will add up more quickly on the tractor because it'll take more time. Regardless, Oil is Oil and Filters are Filters... you'd have to spend money for them for either machine. Tires, belts, all those things will wear out on both machines for the hours you're putting on them, but those wear items will usually be more costly on a tractor.
Now, if the OP didn't have ANYTHING yet (no mower or tractor) then the discussion would change I think. He could then decide on the debate of "1 machine or 2"... But since he already has a ZTR, and it's paid for, it seems the best option (unless money really factors in) is to keep it and get a tractor to handle the "Tractor" work he needs. He'll save money right off the purchase because he won't need a mid-PTO or mowing deck. That'll probably equal the money he'd get from selling the ZTR anyhow.
Understand and sort of agree with you... however I believe he talked about 2 acres so the time maybe doesn't add up as fast as yours... even if you have lower hrs on each machine, I would bet the total maintenance cost of having two will be significantly higher than one... especially when a major repair comes along. Like I said before, if money is not a huge factor then of course hold on to the ZTR. More tools is always better when $ aren't in the equation. Again it is a question of compromise.
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2018 New Holland C227 Compact Track Loader (A56438)
2018 New Holland...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2014 International Maxxforce DT (A53317)
2014 International...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
NEW HOLLAND T4.75 TRACTOR (A52707)
NEW HOLLAND T4.75...
