Am I missing something?
/ Am I missing something? #1
Mark@6308
Bobcat 863
Hi Bobcat guru's,
I've got a Bobcat 863 that I'm replacing some leaking O rings on, however in looking around I found what looks like a broken off pipe. Looks like it's situated on top of the fuel tank, just inboard off the fuel return line.
The Bobcat is currently bogging down hard under heavy engine load but still runs, does smoke a bit though.
I was looking through the right side inspection plate trying to find the fuel pick up line when I saw this other fitting.
Any ideas what it might be, and am I in the right area to find this fuel pick up?
Cheers all
/ Am I missing something? #4
Its not uncommon on the 63 series for the fuel pickup tube to deteriorate. Another thing that will cause it to fall on its face is the main drive belt slipping. I have a 763G and its been pretty good.
I was looking at it this morning and was wondering if I could relocate the fuel pick up entry to just above the drain plug as this is easy to get to, allowing for quick cleans of the filter on the end of the pick up tube?
Edit- After thinking about it, grommet wouldn't seal well enough to stop fuel pushing out due to weight is fuel in tank
/ Am I missing something? #6
I went through the "fuel pickup" thing on an 863G not that long ago. I found it impossible to reach the fitting on top of the tank. My understanding is access is gained by removing the engine. You've got to be kidding me. We fought the problem for six months or so and it came back two or three times. The last time it happened I tried a work around. I removed the fuel filler cap/neck from the hose leading into the tank. Inserted a length of 3/8" copper tubing down the hose so it nearly reaches the bottom of the tank. Put a 90 on the top end and brought it out the breather vent fitting on the filler neck. Attached a length of rubber fuel line to that leading to an electric fuel pump in the engine compartment. Worked like a charm. Has been probably a year or more now with no problems.
I just finished installing a reman engine (Kubota) in another machine and it has much more room to access the fittings on the tank. The Deutz in the 863 was just too tight. I could barely get a fingertip to the line but couldn't do anything with it.
/ Am I missing something? #7
Mine has the Kubota and while not a breeze to do it is doable. Have never worked on one with the Duetz.
This is a good work around, might try this.
The electric fuel pump was to assist the mechanical pump on the Deutz? How did you go about wiring it in.... off a constant hot wire in the engine bay or down to battery and up to a switch?
Cheers
/ Am I missing something? #9
Just tied it to the fuel shut off solenoid. Key is on, shut off solenoid is on, pump is on. Simple.
/ Am I missing something? #10
In fact, I put a pump on the Kubota engine I just installed on another machine. I never cared for Bobcat's idea of the primer bulb for the fuel system. I put the electric pump on the Deutz engine some years back. It just makes things so much easier.
/ Am I missing something? #11
Cheers
If you decide to try what I did, be aware there is a screen in the tank below the filler hose. I had to remove the hose from tank to get to it and pull it out. With that gone the tubing slid right down through the hose. I cut a couple of notches on the sides of the tubing close to the end so there is more than one path for fuel to enter the tube. I considered some sort of screen on the end but decided it would probably fall off at some point in time. I was a little concerned that the added bulk in the hose might affect flow into the tank when pouring fuel in, but have heard no complaints so I guess it's not a problem. I was also a little concerned about eliminating the vent hose but that was a non issue as well. It all seems to work just fine.
What sort of screen is at the top of the tank?
I've spent most of the day trying to get to the clamp holding the bottom of the hose to the top of the tank, and am pretty much over it.
Considering punching something metal down through the filler hose in the hope of giving me room to push the fuel line down.
If I had my shed up I'd pull the damn motor out.
/ Am I missing something? #13
No, you wouldn't pull the motor out. The screen is a brass mesh, about the size of the hose I.D. and about six inches long. I don't remember having much trouble getting it out once the hose was off. I do recall it was a hot sticky July afternoon and standing on my head dripping sweat while doing it made me wish I was somewhere else.
2011 WESTERNSTAR 4900SA (A63569)
2011 WESTERNSTAR...
2020 PETERBILT 367 (A63569)
2020 PETERBILT 367...
Wolverine Skid Steer Tree Digger (A64047)
Wolverine Skid...
MILITARY STYLE S/A CARGO TRAILER (A63291)
MILITARY STYLE S/A...
2012 POLAR TANK TRAILER (A63569)
2012 POLAR TANK...
2017 New Holland T.4 100 w/ Loader (A64047)
2017 New Holland...
