Always Set Parking Brake!
   / Always Set Parking Brake! #51
I've made a number of modifications to my tractor over the years. One of them was to modify the brake to make it extra safe. Our property is in the mountains and nothing is flat. All of my tasks are pretty treacherous and must be done with safety in mind. After using the tractor for a couple of years, I decided I really didn't like the way the parking brake was setup to work.
The parking brake works fine but the design is that you press the brakes down and then press the parking brake pedal which locks the brakes down against the floor. To disengage the parking brake... you press the brake pedals down again, which removes the parking brake.
That's great... unless something magical happens that makes the parking brake become unlocked. For example... magic, or entering the tight confines of the cab with big boots on and accidentally hitting the brake pedal while not seated in the tractor yet, or while chainsawing a tree branch... said branch falls through the open door of the tractor and smacks the brake pedals, etc. Basically, it wasn't safe enough for my liking.
So I modified the brake pedals with a bracket bolted to the cab firewall and a pin which goes through the bracket and brake pedals to lock the pedals down to the floor. So basically, the parking brake is ON and the pedals are locked down to the floor with the pin. There is no movement of the pedals possible when the pin is in place. I never leave the tractor without that pin in place.
In addition, if the backhoe is on the tractor I use it to block downhill movement. If the chipper is on the tractor I put it down to slow downhill movement (probably need to weld some spikes on the bottom of the chipper to make this more effective).
   / Always Set Parking Brake! #52
When I was about 18 I got a summer job as a stableboy at a small private girls camp :)
There were 4 of us "boys" and maybe 20 or so horses. We had an ancient 2 ton "farm truck" to haul the manure. One day somebody parked it where we emptied it with a full load in the morning. On a hill in front of the stable. Later as 2 of us were in the back shoveling the product out it started to roll. Luckily one guy was quick enough to jump in and brake it before it rolled the 20 or so yards and crashed into the barn.
That was my lesson in the importance of confirming equipment is "locked down".
Bi-Parting Driveway Gate (A55853)
Bi-Parting...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A55315)
2023 New Holland...
2012 FREIGHTLINER DURASTAR 4300 M7 SBA 4X2 BUCKET (A57192)
2012 FREIGHTLINER...
Horse Weathervane (A55853)
Horse Weathervane...
Sturtevant Shop Fan (A56469)
Sturtevant Shop...
(INOP) 2007 HONDA 420 ATV (A57192)
(INOP) 2007 HONDA...
