Always check lug nuts frequently
/ Always check lug nuts frequently #1
buckle97
Platinum Member
McComb, Mississippi
Kubota L3830GST
I had bush hogged Monday night and was making a counter-clockwise pattern so I was watching my line with the front right tire. Tuesday I started on another pasture and was going clockwise and watching the front left tire. I only made it about 300 feet when i noticed the wheel was wobbling really badly. I got off to inspect.
I guess I'm just lucky that sixth bolt didn't come off. I would have hated for the front end of the tractor to go down like that. Notice not only are the nuts gone but also the wheel studs. Of course I had taken the front end loader off to bush hog so I had to manually jack up the front axle. Five new studs and I'm almost back in action.
I had to fix a flat on the other front tire about a year ago so I double checked those lug nuts yesterday and they are all tight. These may have worked themselves loose over time as I will admit that I've never bothered to check their tightness in 300 hours. Five new nuts and I'm back at it.
/ Always check lug nuts frequently #4
Other fix
/ Always check lug nuts frequently #5
I,m glad You caught it in time :eek: . You said the studs were missing , as in broke off . Kind off looks like it from the pics or did they unscrew ? . Bob
/ Always check lug nuts frequently #6
Look snapped off in ther pics...I think that maybe replacing the 6th one would be prudent, as it was no doubt stressed beyond normal, and is a prime candidate to fail next....
I assume they unscrewed, but I'm not sure. There was no damage to the threads and I had no problem screwing the new studs in. I didn't think about replacing the sixth stud.
/ Always check lug nuts frequently #8
Know the feeling, I had one side come loose when I noticed a bad wobble driving to a job site.
Tightened them up enough to get back home.(vice grips (AKA one size fits all)are a must in the toolbox)
Only problem was that all the rim holes were elongated and I had to weld a plate with accurate holes in order to have accurate spacing for the lugs.
Worked out OK and I now have a much stronger rim center than before.
Needless to say lug torqueing is now as frequant as oil checks.
/ Always check lug nuts frequently #9
I have driven back from a field before after a puncture on three wheels with a bit of wood chocking up the rocking front axle to keep it off the ground :D
Not very safe I don't think... it was with an old 2WD Massey 165, don't think I'd try it with a modern 4WD!
/ Always check lug nuts frequently #10
Don't forget to check the lugs on your trailer tires too!!! I found that one out the hard way last year! Was driving back home with tractor loaded on trailer and noticed something wasn't right with the trailer. Pulled over and front left tire was loose and wobbling all over the lugs. Walked around to the other side and the right rear tire was GONE, along with ALL the lugs!! :eek: I still have no idea where that tire went either!
I just hope it didn't roll into someone's car or house and bang it up! :eek: :eek:
Called a friend who brought his trailer, we loaded the tractor onto it, and I was able to tighten up the bummed up lugs on the leftside. It was enough to keep that tire on tight enough that I could limp home at about 40mph. Cost me about $200 to put new studs in two hubs, two new rims, and another (used) tire. Now I check them before I haul the trailer even 1 mile down the road LOL!
/ Always check lug nuts frequently #12
Bizarre incident. Good tip though, thanks. I always wonder when I see stuff like this whether or not it happened slow over a long time or really quickly.
On trucks around here they often put plastic "triangles" on each wheel stud with all of the triangles lined up in one direction. That way the driver can very quickly see if a lug is loose during his or her circle check.
/ Always check lug nuts frequently #13
My boss ran the Massey 165 diesel while I drove the 135 gasser. On day he was mowing and the left front tire fell off. :eek::eek::eek:
Those 165's most have been a good seller. My wife's grandpa bought one and its still on the farm. I saw one on a trailer this week.
Later,
Dan
/ Always check lug nuts frequently #14
that's what people do to get back at someone, except it's usually the front tire of a car. thanks for the info. time to check tractor bolts.
/ Always check lug nuts frequently #15
I am hearing more of these loose bolt problems. Is the wheel bolt tapered or flat. the best idea is to use a flat bolt with washers and lock washers to keep your wheel on. Kubota seems to have created a problem inadvertently.
/ Always check lug nuts frequently #16
I'm a tad bit suspicious. That many lug nuts gone at the same time and no thread damage?
I would submit that perhaps someone was interrupted trying to steal your wheel and tire.
/ Always check lug nuts frequently #17
Yep, happens more often than you think. I had a customer who we had sold a set of steel radials for his truck come back the next morning madder than a hornet, stating we had left the lug nuts loose on one of his tires. Further investigation showed he had stayed at a motel for the night and was a victim of tire theft that was interrupted in the night.
/ Always check lug nuts frequently #18
It might be suspicious or it might not. Every time the wheels are removed on my Volvo (car) I have to retighten the lug bolts. The first time this happened we were on the highway driving to the city. A wheel wobbled so bad that one of the lugbolts was missing. This has happened through 3 sets of tires so far.
Oh, and yes they are torqued to specs.
Haven't had a problem with the tractor but I have found slightly loose nuts in routine checks.
/ Always check lug nuts frequently #19
My owners manual says to check my wheel bolts every 10 hr or daily.
How 'bout yours ?
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
New/Unused 2 Post Car Lift (A61165)
New/Unused 2 Post...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
2000 Bobcat 763 (A60462)
2000 Bobcat 763...
(APPROX.100) UNUSED KJ 10' HD GALVALUME STEEL (A62131)
(APPROX.100)...
(2) 10 LUG WHEEL SPACERS (A62131)
(2) 10 LUG WHEEL...
