Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 52,238
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Ok, here we go. At work, we use 21 cy aluminum dump trailers to haul dirt, etc. The other day a backhoe operator loading one of our trucks knocked a hole in a non-structural piece of 'decorative' aluminum ribbing on the truck.
The piece from the dealer is way expensive. The local weld shop wants nearly 200$ for the repair.
Our mechanic has experience welding with a wire welder.. and is good at it.. even has some stick experience.. and is good at it.. but he doesn't like it.
We have a wire welder and an old big lincoln stick at work, but I have a small stick welder rig... low is auto up to 40 amps, high is 70 amps... takes the small 1/16 - 5/64 sticks.
I noticed that tractor supply has aluminum welding rods..... in that size..see where I'm going with this. Anyone care to share any hints/tips/advice on stick welding this aluminum? Patch will not be structural, and will be less than 1' x 1'.
thanks
Soundguy
thanks
Soundguy
