Threepoint
Veteran Member
- Joined
- Feb 13, 2014
- Messages
- 2,233
- Location
- No. VA
- Tractor
- Kubota B2150HST w/ LA350 loader, Kubota GF1800 HST, Kioti CK3510SE HST w/ KL4030 loader, Kioti NX4510HST/cab w/ KL6010 loader
In another thread today, the comment was made that some tractor brands are using aluminum instead of cast iron for certain key components on SCUTS and CUTS, including transmission cases. I hadn't thought much about this, but it has me curious.
I'd like to learn more about this, from the collective wisdom of the TBN community.
Especially advantages and disadvantages of aircraft-grade aluminum vs. well-cast, ductile iron for various parts. One situation that comes to mind is hooking up a PTO-driven implement with a shaft too long for the tractor. A broken transmission case can result when the hitch is suddenly raised too high. Would the aluminum or cast iron be better able to withstand the force? :scratchchin: This is just one example where I'm thinking it might make a difference, depending on the goal of the material choice.
