Aluminum Trailer Cleaning Products
   / Aluminum Trailer Cleaning Products #1
wsp617
Wisconsin
JD 1070
I just bought a 7 yr old aluminum single axle utility trailer. It's in really good shape but the aluminum has lost it's shine. I'd like to get back that shine a new trailer has. I found a product online called Streak Master. They claim their product will work for that.
Has anyone used this product or one like it? Do they work well?
The trailer has a bed made off green-treated 2x6's and I don"t want those to get all discolored either.
   / Aluminum Trailer Cleaning Products #2
I have heard that semi trailers are brightened at truck washes by using a acid in a pump up garden sprayer then rinsed off with water. I think its hydrofluoric acid but not sure.
I would be interested in this also. We have some aluminum boat trailers that are getting dull.
Chris
   / Aluminum Trailer Cleaning Products #3
The truck wash has a acid that will clean a badly faded cattle trailer to a new look.
Don't know the name of the acid but it works good.
And not what would call expensive cost.
ken
   / Aluminum Trailer Cleaning Products #5
I work at a truck shop and we use a brightener chemical (acid) and it works well. When Im at work today Ill try to see what the ingrediants are or the name of the stuff. It is pretty potent though, we wear rubber gloves, apron, and face shield when using it. We use it on fuel tanks, wheels, trailers, etc.
   / Aluminum Trailer Cleaning Products #6
The Blue Beacon truck wash near me does the acid wash for $25 or $30 according to a friend who had a horse trailer done recently.
I don't like it because the aluminum gets chalky and white in a short time. I use a Mothers power ball in a drill with some polish on my horse trailer. Yes it takes a while and most folks call me crazy, but it looks a lot better that the acid wash. My BIL does the same thing to his boat trailer. I usually posish mine once a year and it looks better than new. I probably would not go through that much trouble on a utility trailer, but to each his own.
   / Aluminum Trailer Cleaning Products #7
what you are referring to is hydrofluoric acid. you can get it in a concentrated form and mix 1 to 10 water ratio. The biggest problem is that when applying, you must not let it dry out till you rinse it off.
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
2018 MACK PINNACLE WINCH TRUCK (A53843)
2018 MACK PINNACLE...
2005 Ford F650 SVI Crew Cab Hazmat Truck (A52377)
2005 Ford F650 SVI...
2016 Ford F-550 Ext. Cab Flatbed Truck (A52377)
2016 Ford F-550...
2013 Club Car Carryall 252 Electric Utility Cart (A51694)
2013 Club Car...
2015 Ford F-350 Dump Truck (A51691)
2015 Ford F-350...
