Aluminum Air Compressor's And A Note To Owners
   / Aluminum Air Compressor's And A Note To Owners #1
JimR
Elite Member
Central Ma.
Kioti NX4510HST
Aluminum Air Compressor\'s And A Note To Owners
Yesterday my aluminum two stage air compressor made by Devilbiss blew a head gasket. This information is for anyone owning an aluminum compressor. Check your head bolts to make sure they are tightened down. Out of 6 bolts on the head, only 3 of them were tight. The other 3 were snug. The owner of the service center where I bought my new gaskets told me that is normal for these compressors. He said that they loosen up over time. So check your head bolts and save yourself about $75.00 for a new gasket set. /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif
   / Aluminum Air Compressor's And A Note To Owners #2
Re: Aluminum Air Compressor\'s And A Note To Owners
Yep, Jim, and another problem I've seen with those compressors is when the owner opens the oil fill plug, sees oil down in there, and thinks it's OK. Unfortunately, it's a very shallow oil sump and needs to be filled all the way up just to the point of overflowing, or it may not have enough and will burn up the compressor.
Oops, let me add that I've only seen that on the single stage, but two cylinder, DeVilbiss; have no experience with their two stage compressors, so the above paragraph may or may not apply.
Hi Bird, The two stage has an oil fill line haflway up the glass. I keep mine filled almost to the top also. Especially since it is a splash type oiling system.
   / Aluminum Air Compressor's And A Note To Owners #4
Jim maybe it don't apply but be sure that is the recommended level. With a splash system to much is as bad as not enought
Charlie
   / Aluminum Air Compressor's And A Note To Owners #5
OK, Jim, forget what I said above. That one obviously has a deeper sump and half way on the sight glass would be correct.
1067 (A53342)
1067 (A53342)
2005 Chevrolet Colorado 4x4 Pickup Truck (A51692)
2005 Chevrolet...
2019 Ford F-550 Service Truck, VIN # 1FDUF5HY1KEF71327 (A51572)
2019 Ford F-550...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
2023 John Deere 8R 280 MFWD Tractor (A53342)
2023 John Deere 8R...
