Aluminum Air Compressor's And A Note To Owners
   / Aluminum Air Compressor's And A Note To Owners #1
JimR
Elite Member
Central Ma.
Kioti NX4510HST
Aluminum Air Compressor\'s And A Note To Owners
Yesterday my aluminum two stage air compressor made by Devilbiss blew a head gasket. This information is for anyone owning an aluminum compressor. Check your head bolts to make sure they are tightened down. Out of 6 bolts on the head, only 3 of them were tight. The other 3 were snug. The owner of the service center where I bought my new gaskets told me that is normal for these compressors. He said that they loosen up over time. So check your head bolts and save yourself about $75.00 for a new gasket set. /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif
   / Aluminum Air Compressor's And A Note To Owners #2
Re: Aluminum Air Compressor\'s And A Note To Owners
Yep, Jim, and another problem I've seen with those compressors is when the owner opens the oil fill plug, sees oil down in there, and thinks it's OK. Unfortunately, it's a very shallow oil sump and needs to be filled all the way up just to the point of overflowing, or it may not have enough and will burn up the compressor.
Oops, let me add that I've only seen that on the single stage, but two cylinder, DeVilbiss; have no experience with their two stage compressors, so the above paragraph may or may not apply.
Hi Bird, The two stage has an oil fill line haflway up the glass. I keep mine filled almost to the top also. Especially since it is a splash type oiling system.
   / Aluminum Air Compressor's And A Note To Owners #4
Jim maybe it don't apply but be sure that is the recommended level. With a splash system to much is as bad as not enought
Charlie
   / Aluminum Air Compressor's And A Note To Owners #5
OK, Jim, forget what I said above. That one obviously has a deeper sump and half way on the sight glass would be correct.
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A52748)
Hay Van FL-95 Bale...
Cat TH407C Telehandler (A52748)
Cat TH407C...
2009 Ford F-650 24 ft Box Truck - 6.7L Cummins L6 Engine - Automatic Transmission - Low Mileage (A52748)
2009 Ford F-650 24...
MAHINDRA MAX 24 HST COMPACT UTILITY TRACTOR WITH LOADER (A52748)
MAHINDRA MAX 24...
2012 CHEVROLET EXPRESS (A52472)
2012 CHEVROLET...
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
