Alternator ?
/ Alternator ? #1
KoonHunter51
Marshall, NC
FarmPro (Jinma)2430
Jinma 304 FarmPro 2430
Existing Jinma Alternator 2JF200
Will a JF11 or JF15a work on this tractor TY395 engine ?
Even if mounting is different could dismantle of JF11 or JF15a be used to rebuild the 2JF200 ?
/ Alternator ? #3
Far better to replace with a one wire Denso alternator.
Even GM is using Denso instead of Delcotron.
35 amp Denso for about $56 on ebay.
CHEVY MINI ALTERNATOR DENSO STREET ROD RACE 1-WIRE - 35 AMP! | eBay
To have a easier and better indication of your charging voltage and state of battery use a simple LED voltage display.
Less that $10.
I suggest this supplier as they have product in the USA for faster delivery.
DC 12V-24V Auto Motorcycle LED Panel Digital Voltage Volt Meter Display 3 Colors | eBay
This is a photo of both the one wire alternator and the voltage display.
Dave M7040
/ Alternator ? #4
Hello Dave,
I went with a similar AND0212 from DB Electrical. I'm putting it in a Foton FT404 and didn't want to fry any wires with the 63 amp 10Si I originally bought. My question to you is the 2 pin "T" connector on the rear, where do I connect these wires too? Also I'm trying to get the instrument panel working again, where should I hook into the harness? The fuse block where the deleted voltage regulator socket is that way it's going through a fuse, or the key?
Any help would be greatly appreciated.
Thanks for your time
Dwayne.
/ Alternator ? #5
Hello Dave,
Dwayne.
Sorry. I do not understand your question. Are you trying to install a one wire Delco alternator or another make? The AND0212 from DB electric is a DENSO three wire alternator not a one wire which is the one I suggest people use. Not knowing your FOTON's wiring, trying to get the instrument panel working as new, is not something I can help you with.
Your question: Where do I connect these wires. Which wires, the ones on the voltage display? If those are the wires you are talking about, they have no connection to the alternator which is why it is so easy to install.
Connect one terminal of the display to the battery ground terminal, the display's + terminal can e connected to the battery b+ where it will stay on all the time using very little power or to any wire from the key switch which turns on when the key is in the ON position.
Depending upon what you are trying to accomplish, see if you can return the 3 wire DENSO for a one wire. It will be much simpler.
Dave M7040
/ Alternator ? #6
I was referring to the 2 pins on the back of the alternator that form a "T". It looked like the one you recommend, I didn't notice the "DB Electrical AND0212 Alternator For Chevy Mini Alternator For Denso Street Rod Race 3-Wire in description till you mentioned it. Take it they use a generic picture for most. I was more concerned with the 30 amp rating.
/ Alternator ? #7
The one wire Denso's sold on ebay, clearly only show one wire terminal on the rear of the alternator. They are also available from 35 amps to at least 90 amps.
Dave M7040
/ Alternator ? #8
Could you post a photo of the connector, and the exact model of alternator? The connectors that I've seen which could be described as T shaped are actually housings holding three female blade connectors, two 9.5mm as the output and one 6.3 for the warning light. But that doesn't sound like your alternator.
/ Alternator ? #9
You could go like I did to DB electric and search on their site for the AND0212 Alternator.
There are only two terminals like a Delcotron but one is at 90 degrees to the first unlike the Delco one.
Dave M7040
/ Alternator ? #10
I think your right, I didn't see the top of the "t" connector. I was looking at the angle picture.
I even bought the 2pin T connector.
I ordered :DB Electrical AND0212 Alternator For Chevy Mini Alternator For Denso Street Rod Race 3-Wire,Case Trencher Uni-loader Grasshopper Tractor,Gravely Tractor,Kubota Excavator,Tractor,Loader,Mower
From Amazon waiting on the alternator and connector. Now that I see the 3rd I'll have to order another if the alternator will work
Thanks again for all your help
/ Alternator ? #11
Everyone has got you completely confused. There is one large output terminal and then in another location two small spade connectors. There is no other spade connector.
Look at this blown up picture of what you ordered from DB electric.
Your big mistake was not ordering a one wire alternator. Now life will be much more complicated as you try and integrate the two small terminals into your existing wiring system.
Dave M7040
/ Alternator ? #12
If you go to Amazon
and view the 4th picture, it appears to have the 3 pins as aesmith suggested. I'll find out tomorrow, and let you know.
If it's 2 I found this:
/ Alternator ? #13
Great. Actually that's not the same three connections that I was expecting, normally the third wire is remote sense. However at least it shows you how to wire up. Both "switched live" and "ignition light" need to be via the main switch, ie Off when the tractor is switched off. What I don't know with this particular alternator is whether it will work correctly without the warning light. Some rely on current from the light to start the alternator charging, but on some Japanese alternators that function is provided by the switched live, and the warning light is optional.
/ Alternator ? #14
Incidentally and not to state the obvious, you don't have to use the special connector, you can use two normal blade terminals on your wires. The special connector is just for convenience and to stop you connecting the wires the wrong way round.
2023 VOLVO L90H WHEEL LOADER (A64279)
2023 VOLVO L90H...
Denis Cimaf Hydraulic Mulcher Skid Steer Attachment (A66734)
Denis Cimaf...
PORTER CABLE AIR COMPRESSOR (A67714)
PORTER CABLE AIR...
JOHN DEERE 5045E TRACTOR (A65057)
JOHN DEERE 5045E...
2026 GIYI FB77 Feller Buncher Skid Steer Attachment (A66734)
2026 GIYI FB77...
2016 Ford Escape SUV. (A66738)
2016 Ford Escape...
