alternator problems
/ alternator problems #1
BullCreek
I have a JCB midi cx tractor loader backhoe I bought new that has been a super solid machine for about 10 years. Lately it has developed an electrical problem that I think may be related to the alternator. It had been acting like the battery was not very hot (not much cranking power) even after using it for hours for a while and then on Wednesday it started blowing the 40A ignition fuse immediately when I tried to crank it. After going thru several fuses, I started to track down potential electrical problems. One of the terminals on the starter was totally rusted up and corroded, and when I went to unhook it to clean, it broke off - so I took out the battery (had it tested and was fine both on voltage and cranking amps - which wasn't surprising because it wasn't very old) - and replaced the starter - but same problem immediately blowing fuses. Eventually, I realized if I left the wire going from the alternator to the starter off - it would crank over like new, start, and run fine. Unfortunately, it of course wouldn't charge the battery in that condition. Equally unfortunately, I had a lot of work to do, so thinking that it wouldn't do any damage other than running the battery down, I just left the alternator disconnected and went about my work. Eventually after about a day of work and changing many different hydraulic implements which required an engine stop/start the battery ran down. I jumped it and let it charge and it started fine, but at this point, the hydraulics were dead (not to the axles just everything else).
I've heard that if the diode/rectifier in the alternator goes bad it can put a substantial draw on the battery - I'm wondering if this is why the fuse was blowing and why when it was hooked up the tractor acted like it didn't have much cranking power for the last month. I took the alt off and took it to two different auto parts stores and they could find it in their system but both said they didn't know how to test it because it wasn't a standard car/truck alt. Is there a way to easily verify the diode is bad - it has three terminals - the big one that goes to the starter is labeled B+, one labeled D+ I assume might be the diode, and one labeled W I'm not sure on? I think this is the alt (for a heckuva lot less $ than either of the parts houses wanted) - the JCB has a 50HP Perkins in it that is the same as cat and others use in a lot of their smaller skid steers, etc.
Amazon.com: DB Electrical ALU31 Perkins Engine Alternator For Lucas 24479,24481,24344,24479,2448,24481,Jcb 7144152, 714322, 714/322, 714/4152,714/4153,Caterpillar 225-3141,225-3143, 35-3661: Automotive
Are there not shops around that rebuild fix alts anymore - I asked both Napa and Oreilly and they acted like they had never heard of such but I'm pretty sure that's what we did when I was a kid and dad's tractors had alternator problems.
Does my theory above about the alt match the symptoms/seem likely?
On the hydraulics - I checked all the fuses and they looked ok - but I'm wondering if maybe some wild ac before I disconnected it or using it with lower voltage maybe messed up one of the relays that engages the hydraulics. Any thoughts?
/ alternator problems #2
Check local phone book for industrial shops that do forklifts and big truck and industrial engine repairs or "automotive electrical services" ... Most "auto parts" can't even find the windshield washer fluids, all they know is how scan product codes on cash register any more....
On many alternators the D+ goes to a charge indicator light (ALT lamp) ... Most modern alternators need a shot of 12 volts to initialize the charge sequence teh get this through ALT lamp... Theory is there is 12 volts form ignition on one side of idiot light, and when alternator is not spinning up there is ground on other side of light (from alternator)and lamp lights, as alternator spins up it produces 12 volts on D+ terminal and then you have a situation where you have 12 volts on both sides of idiot lamp and there is no current flow so light goes out indication the is output at alternator B+ and D+ terminal..
Might try something as simple as this test on alternator... Dont know if its really valid in your situation, but does not cost much to try....
Quick Alternator Diode Test - YouTube
Also...
Alternator Terminals Explained | JAS Oceania | Auto Electrical Products
Dale
Thanks for the links and comment. I got out my meter and did the diode test - it appears to be ok - got 580mv one direction and nothing the other way. I will call around tomorrow and see if I can find a shop that can test it fully tomorrow or perhaps opine further on the symptoms.
2006 Ford F-350 12ft. Flatbed Truck (A61573)
2006 Ford F-350...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
CFG QK18R (A64127)
CFG QK18R (A64127)
New/Unused 3-in-1 Quick Attach Frame (A65583)
New/Unused 3-in-1...
2001 GMC C7500 Fuel Truck (A62613)
2001 GMC C7500...
2019 KUBOTA KX057-4 EXCAVATOR (A62129)
2019 KUBOTA...
