Alternator Problem on M4900
   / Alternator Problem on M4900 #1
docmx
I have a M4900 with 300 hrs. Replaced the battery about 6 months ago and now find myself having to replace it again after 6 more months. Before the 2nd battery died, I noticed the alternator light was turning on and off. I put a new battery in and started it and the alternator light would not turn off. Before I take the alternator off to have it tested...does anyone have a suggestions for things I should check. The belt is good and tight and does not slip while the engine is running. The two connectors on the backside (the plastic plug connector and the post connector with the rubber cover over it) of the alternator are good and tight. The wires appear to be in good shape. Ideas appreciated...
   / Alternator Problem on M4900 #2
If you have a volt meter available, you can hook the positive lead to the large wire terminal at the alternator(output) and negative to ground. Reading should be 13.5 to 14.5 volts with a fully charged battery at about 2000 RPM.
John
   / Alternator Problem on M4900 #3
Doc:
be sure connections are clean and brite on the battery cables too. a little bit of fur on the connections can cause some confusing issues.
simonmeridew
Thanks, I will look into these suggestions. Anyone else have suggestions?
I checked the alternator output voltage and it was 15.67.
That was at idle.
Thanks for that tip!! I will look into it.
   / Alternator Problem on M4900 #9
Builder said:
Had the same problem on my Deere. It was the voltage regulator.
If the voltage regulator is malfunctioning it is cheaper to replace the whole alternator than to replace the built-in regulator section of it. The link is to an equivalent to Kubota 34070-75602 used on the M4700 and M5400 - likely the same for the M4900. I recently bought an alternator from these people - it's perfect and yes it really was 70% less than list!
   / Alternator Problem on M4900 #10
Mine was an external voltage regulator :)
   / Alternator Problem on M4900 #11
Ah - for the good old days when regulators had relays and contacts and were the size of a loaf of bread !! You could open them up, cure what ailed them and send 'em back in for a few more laps.:)
   / Alternator Problem on M4900 #12
I agree with that statement but IC boards has forced us all to become parts changers without expensive factory sanctioned software to diagnose internal voltage limiting resistance in sealed logic boards.
   / Alternator Problem on M4900 #13
I recommend taking off all of your ground cables on the tractor and cleaning the ends and the places they bolt to completely free of all paint corrosion and whatever else then putting them back on tightly. If I remember right you should have one big one from the starter to the engine and another from the engine block, or frame to the battery. Some models just had one but clean them all whatever you got.
It's almost always the problem I fixed on them when I worked on Kubotas.
40' CONTAINER (A52706)
14C SCRAPER (A58214)
2025 CFG Industrial MX12RX Mini Excavator (A59228)
2025 CFG...
2009 Honda Civic Sedan (A59231)
2009 Honda Civic...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
