Alternator Problem Maybe
/ Alternator Problem Maybe #1
Believer
I've got an old Ford 800. Battery dead, 5 years old, so I thought it was reasonable. Put in a new battery, started and mowed for a few hours. I shut if off and started it again. Next morning, battery dead. Recharge battery, disconnect alternator since I couldn't find any short anywhere. Started next morning. Seems like the alternator is draining the battery. Is there a way I can test the alternator? Thanks.
/ Alternator Problem Maybe #2
............. Is there a way I can test the alternator? Thanks.
Some Advance Auto Parts stores can test alternators. A few years ago they would do it for free -- maybe they still do. Give them a call.
/ Alternator Problem Maybe #3
There is an easier ways;
1 - Start the tractor
2 - Disconnect the positive cable on the battery
3 - Check the voltage at the cable to ground, it should be around 14 volts (you may have to reeve the engine slightly).
The other way is to hold a screwdriver blade next to the alternator / generator shaft at the back side with the engine running. If it is charging there will be a strong magnetic field and the blade will be pulled to the shaft.
Hope that helps.
E/S
/ Alternator Problem Maybe #4
Does it have a alternator? My 861 had a generator until we did a alternator conversion. Is it a 6 volt battery? If so I am guessing its a generator.
Chris
/ Alternator Problem Maybe #5
If it is 6v., then you should have 7v.
/ Alternator Problem Maybe #6
to check system for drain on battery, disconnect either batt cable with key off, engine off. connect ammeter one lead to batt cable, other lead to respective batt post, it will show amount of drain if present. to check your setup, turn key switch on with ammeter in place, if correctly hooked up you will see meter show the drain. if you have a drain with key off, disconnect alternator, assuming you're using a delco with internal regulator, if drain disappears, you found it. if you are using alt with external regulator, disconnect regulator as well as alternator, one at a time and check. you can also use a test light, hooked up the same way, aligator clip on cable, probe on batt post, in series with batt, if you have a drain bulb will burn. with everything off, test light will be off. to check charging system, NEVER disconnect battery cable with engine running. a charging battery gives off hydrogen gas, even a small spark could cause battery to explode. i have seen two explode, like a stick of dynamite. to check, put volt meter on batt terminals. better to check amperage, but if proper voltage is present, its charging. test light method for drain is more than adequate for your tractor. hope this will be of some help.
/ Alternator Problem Maybe #7
Hope that helps.
E/S
Never operate an alternator without it being connected to a battery. Doing so is the best way possible to damage a perfectly good alternator. he same voltasge test should be performed with the battery connected, and withthe tractor both running and not. There should be a voltage difference between the two tests. In this case, we may also have a bad diode set in the alternator which is allowing the alternator to drain the battery at rest. Often an alternator will charge OK with this problem.
/ Alternator Problem Maybe #8
Did you guy miss that this should not have a alternator unless converted to 12 volts???? The 800 series Ford tractors had a 6 volt system, positive ground, and a generator, no alternator.
Chris
/ Alternator Problem Maybe #9
G'day i think you have done your own test, disconnected and no prob if you really want to test hook it back up again and see if it goes flat again i would say you have blown a diode if it is an alternator
Jon
/ Alternator Problem Maybe #10
Assuming that this tractor has been converted to 12v properly and it's worked as desired for a time, for a good battery to drain down over night, there has to be something thats connected directly to the battery thats finding it's way to ground.
In an alternator there are reverse current diodes installed that are supposed to prevent a batt from dischargeing through the alternator but if they are blown and shorting out, they would be the primary cause IMHO. Alot of conductive material built up on the starter solenoid at where the main hot battery cable connects is another.
It's never good to throw new and sometimes expensive parts at a problem until one has tried to isolate via troubleshooting.
One of the best and easiest ways to troubleshoot a possible battery discharge problem is to make up a simple tester w/an automotive type bulb, I use an 1156 (but any will do), and solder two wires with a bit of length to it. One wire should be soldered to the lead tip and the other to it's case ground. To make sure it's good, just place one wire on the batt + and the other on the batt -, it should glow if it's properly soldered.
Now take the + battery connector off of the battery, leaving the - connected. Wrap one of the testers wires around the batteries positive post and the other wire around the connector you just removed (I use vise grips to keep the wire on the batt post). With the key off, if the bulb glows you've got something thats shorting to frame/battery ground. To determine which device, you can either start removing fuses one at a time or remove the "hot" connector at each device, i.e. starter solenoid, alternator etc., until the lamp goes out.
If the tractor uses a positive ground electrical system, leave the positive connected (ground) and lift off the negative connector (hot).
re. alternators
even with the reverse current diodes they still allow (leak) a very small amount of current through them (milliamps) and a system with a good battery and charging system will keep up with no problem. This cheap lamp tester won't glow in this case because the current isn't sufficient to energize it but, any appreachiable amount of current will glow that bulb. Keep in mind that even if the bulb just barely glows, that signifies too much current is leaking and is a problem.
I like using the bulb over a multimeter because the meter when set to measure millamps will show the normal discharge of the alternator and cause a replacememnt of a properly functioning alternator (BTDT) :D
Generators generally don't have any leaks because their regulators have a cutout relay that opens the circuit when it's not making electricity.
Good luck
/ Alternator Problem Maybe #11
So are you saying that anytime someone jump starts a car they are risking explosion by removing the jumper cables? Same battery charging... same risk of sparks.
Seems a little over the top to me.
/ Alternator Problem Maybe #12
If you had ever witnessed a battery explosion, you wouldn't be so sure. In fact, you wouldn't have posted that.
It is recommended practice to connect the ground to the dead vehicle last, and disconnect it first, using a clean chassis ground rather than the negative post of the dead battery.
The other important reason not to disconnect the battery of a running vehicle with an alternator in the charging system is a high percentage of the time, damage ocurrs to the alternator.
/ Alternator Problem Maybe #13
I saw a battery explode once. We stopped work on the house we were building to eat lunch. Bulldozer operator parked about 50 feet from the porch where we were and ate with us. He got back on the dozer and when he turned the starter switch one of the two batteries exploded and blew the battery compartment door open. Really scared us all. No one was hurt, but it took several buckets of water to flood the acid from the tractor. I think about that every time I jump start a vehicle.
/ Alternator Problem Maybe #14
I haven't ever witnessed a battery explosion, and I've jumped a lot of vehicles. Now that you mention it, I do realize that the proper procedure is to connect the negative ground somewhere away from the battery. I had never thought that it would be to prevent explosions.
/ Alternator Problem Maybe #15
yes i did catch the fact that he said alternator, and i am aware that this tractor any was 6v orginally. whether 6 v or 12 v alt or generator, test for drain is the same. thats why i referred to the delco alternator, i have changed many 6v to 12v, and thats the easiest to wire up, cause of the internal regulator. any parasitic drain seen on meter, will be negligible,because there are no keep alive circuits on this tractor, but a test light, light bulb whichever you choose will do a fine job. i have seen many times the contacts in external regulator stick and be the cause of batt drain. and yes please be aware, booster cables have been the cause of many batteries to explode. RickB gave the correct procedure to make the last connection to hook up and the first to disconnect away from the battery on a grounded part of the chassis.first one i saw explode made a believer out of me. best regards. referring to delco alt, i should have said thats the cheapest with an internal reg.
30 Yard Roll Off Dumpster (A61165)
30 Yard Roll Off...
2020 Ford F-150 Pickup Truck, VIN # 1FTEX1C57LKD02991 (A61165)
2020 Ford F-150...
2016 KUBOTA SVL75-2 (A64047)
2016 KUBOTA...
Decorative Mermaid Statue (A61569)
Decorative Mermaid...
(2) UNUSED 320/70R24 TIRES W/8 LUG RIMS (A62130)
(2) UNUSED...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Peterbilt 567...
