Alternator output
/ Alternator output #1
hosejockey2002
Auburn, WA
Kioti CK20 HST
Anyone out there know the approximate alternator output of a 1401D? I'm going to wire up an inverter to run some mini Christmas lights for a parade. If my tractor's electrical system can handle it I'd like to run the running lights on my trailer too. I hooked in the inverter today and it worked with no problems but I'm not sure if the tractor can handle the electrical load for an extended period of time. If my alternator can't handle the load, I'll just use a deep-cycle RV battery to run the inverter off of. Thanks.
/ Alternator output #2
Why not hook up the tractor alternator to the deep cycle and then the inverter?
Egon
/ Alternator output
That's a good idea, but the more I think about it I just may run the inverter off the deep cycle battery alone. I think it will easily run the inverter for an hour or so if it's fully charged.
/ Alternator output #4
The alternaotr puts out 15amps. Interesting that it actually puts out single phase alternating current, which is rectified in the transistor type regulator.
/ Alternator output #5
Unless you've got a huge amount of lights, running both batteries in parallel on the tractor electrical system w/ the invertor hooked in shouldn't be too bad. If your alternator is 15 amps , and both batteries are charged up good, sounds like a good float.
How many watts is the inverter? Small ( 150 )?
If you've got an ammeter on the tractor, just keep an eye on it. If you are worried that it will be charging at max for too long, rig a isolation switch between the second battery and the tractor system... switch it in and out periodically to give the deep cycle a bit of a rest.
Soundguy
/ Alternator output
It's a 300 watt inverter, but I'm only running a string of 100 mini lights. Unfortunately, I just found out that the parade is for "non-motorized" participants only./w3tcompact/icons/sad.gif
/ Alternator output #7
Well then, I guess that battery is going to get awful heavy with
you running alongside the float with it strapped to your back. :)
/ Alternator output
Naw, the tough part will be me pulling my 16' flatbed trailer with 20 kids on it!! /w3tcompact/icons/laugh.gif
/ Alternator output
That's what the breakaway is for! If it gets away, the breakaway cable I have tied to my wrist will activate and stop the trailer after it runs me over. /w3tcompact/icons/laugh.gif
/ Alternator output #12
Got a better idea for you. Instead of the breakaway cable.. use surge breaks, and a rope around your wrist. When you get sucked into the tires, the rop will put enough tension on the hitch to engage the breaks, then the trailer can skid to a stop on you, much less wear on the tires that way.
Oh, I would wear some clothes that you plan on throwing away.. just a thought /w3tcompact/icons/eyes.gif
Soundguy
2010 John Deere 1770NT Planter (A63109)
2010 John Deere...
Caterpillar 322 Excavator Service and Parts Manuals (A63117)
Caterpillar 322...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
2014 Ford Transit Connect Passenger Van (A61573)
2014 Ford Transit...
2019 Jeep Grand Cherokee SUV (A61574)
2019 Jeep Grand...
2020 John Deere HPX615E Gator 4x4 Diesel Utility Cart (A61572)
2020 John Deere...
