"Alternator Kit"
/ "Alternator Kit" #1
/pine
Super Star Member
From what I understand...my B1700 has a "dynamo" rather than an alternator...is it worth it to upgrade with the Alternator kit ?
I really would like to add some work lights and maybe an inverter...
/ "Alternator Kit" #2
For sure! I put one on my BX to power extra lights and a 12 volt heater off of Ebay for my cab. Lights are really bright and the heater keeps me warm without draining the battery.:thumbsup:
/ "Alternator Kit" #3
The dynamo only puts out 15 amps max, when idling or at lower rpm even a couple of lights could start discharging the battery.
Do you have a number for a kit? My dynamo is fine so far, but I can't see replacing it when/if it goes out if there is a reasonably priced alternative. I've been looking at alternator case sizes, there isn't a lot of space to mount one.
/ "Alternator Kit"
What I am wondering is if there is a cheaper alternative to "the kit"...i.e., is there a something like a delco etc. that is easy to adapt without any fabricating?
/ "Alternator Kit" #5
Delcoes are huge compared to the space available with the side cover on.
The simplest way would probably be to find out what alternator was used in Kubota's conversion kit. Once you have that it would be easy (and cheap) to get one by number. Even the kit I saw had brackets and a harness to replace the external regulator so I don't think you will find a bolt up solution.
/ "Alternator Kit" #7
Hope you were the one who got it and saved yourself $200.
/ "Alternator Kit" #8
The hot rod world is dealing with problems like this for ages. Mini alternators exist - 4" diameter like this one. You can buy one on ebay for less than $100.
But you would have to fabricate a bracket and such.
/ "Alternator Kit" #10
Pine,
I did my BX22 this fall. I also added 3 6" halogens (1 facing forward-2 reverse) I couldn't have added them without the upgrade. I got the kit & had everything installed & back together in 45 minutes. Don't hesitate, go. :thumbsup:
T-Man. :cool:
/ "Alternator Kit" #11
/pine,
If you want to add lights, consider a couple of LED lights. I had a 55 watt halogen on my BX23, and when that burned out I put on an LED from Northern Tool. From what I see it is every bit as bright and uses very little amperage. It is also a much whiter light. Someone said in a different thread that it uses 12 watts, but I can't say for sure. If you want the inverter, well that's another story. You could easily use multiple lights without draining the battery. Here's a link to the light:
Buyers DC LED Utility Light — 12 Volt | Work Lights | Northern Tool + Equipment
/ "Alternator Kit" #12
/pine
If you're the one who got the kit will you post the alternator number. I've looked and see a bunch that look like the one in the kit, many are listed as Nippondenso/Kubota.
10ft Fork Extensions (A64553)
10ft Fork...
48in Farm Jack (A65583)
48in Farm Jack...
Location Info Please
2005 IC Corporation PB105 School Bus (A64194)
2005 IC...
2021 PETERBILT 367 (A65643)
2021 PETERBILT 367...
Pallet of 8ft Metal Roofing (A65583)
Pallet of 8ft...
