alternator kioti dk 35 diesel
   / alternator kioti dk 35 diesel #1
weldonjr
kioti dk35
is it true if I place a screwdriver on the back of an alternator when it is running it will form a magnet affect if it is charging ? kioti diesel dk 35 altermator
   / alternator kioti dk 35 diesel #2
If the brushes are gone, it still won't charge. The best is to measure with a voltage meter over the battery while running engine with a load on it (Lights on).
will the back act as a magnet
   / alternator kioti dk 35 diesel #4
should if working, may if not working correctly
at times i hear a screeching from alternator then it disappears the belt is ok and not slack
   / alternator kioti dk 35 diesel #6
How is your coolant level in the radiator? Belts that have antifreeze on them will sometimes squeal even if they are tight. If the radiator is leaking, the fan can blow antifreeze onto the belt. Worth checking.
If it is antifreeze on the belt, try spraying it with windex or soapy water. Sometimes that will quiet them down. Do this with the engine running.
   / alternator kioti dk 35 diesel #7
Might be the shaft bearings/bushings going bad. Remove the belt and spin the pulley. If stiff or gravely-feeling then that's a sign that it could be the bearings/bushings. NOTE: Running with really tight belt tension can prematurely wear the bearings/bushings.
Might also be that there's variations in the pulley's surface (some rust and then some smooth/shiny areas) and there's varying belt traction.
Also, don't rule out something else in the belt path. Water pump, fan or something else that has a pulley (tensioner). Another component might be the actual culprit.
iit is a loud squeal and it comes from alternator then it disappears
UNUSED LANDHONOR PHA-16-2C HYD 3PT HITCH MOUNT (A54757)
UNUSED LANDHONOR...
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
TORO MBTX 2500 STAND-ON CONCRETE BUGGY (A51406)
TORO MBTX 2500...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
2015 FORD F550 XLT SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F550 XLT...
