Agvg
Elite Member
The alternator is always connected, when starting the rpm are so low that there are no charge, and almost all alternators are self regulating when it comes to current so that's not a problem anyway.
The battery works as a buffer/load and helps the regulator to keep voltage with in specifications, without battery you can get very high voltage spikes and that can fry diodes in the rectifier.I don't see why no battery would fry the alternator. No reason at all. And if they persist, ask them to explain that. I bet they can't
My first question is where is the voltage regulator? Internal to the Alternator? An alternator will produce varying DC level depending on RPM, so you need a Voltage regulator.
It is usually the Diodes that will cause slight leakage, or some call it a rectifier.
But you are talking about voltage regulators with input and output in a traditional way I suppose? Not a voltage regulator that control's a 3 phase generators output by regulating the field in the rotor?Sorry, "BUFFER" is not an electronic term. Neither is SURGE, a term that is always thrown around. I have worked with, designed and build many voltage regulator circuits. Never got spikes on the output. A small cheap capacitor is usually added to the output and input and often several at different values, to stabilize voltage fluctuations and remove transients and noise. Can't see that anyone would build a voltage regulator that relies solely on the capacitance of the battery. Which still would not address the transients. An automotive or tractor electrical environment is very hostile for electronics and any such circuits must be built with this in mind.
Your electric shop may be taking your money because you have it and they don't. They may know little more than you about the electrical system and be shining you on experimenting as they go. Either way you lose. From your tale it sounds as though they have not seen the tractor - this is all hit or miss as you bring them parts. Your description of the way the system is wired sounds as though the alternator is always connected to the battery. If that's the case it is probably trying to work with the battery and maintain current as you have the starter engaged. I think in a normal system when the starter is engaged everything else electrical is disconnected, though I could be mistaken. If the alternator is trying to "help" the battery, it is looking effectively at a short circuit for a brief period of time. This could cook the alternator in short order. You will probably continue to experience electrical problems until you get the wiring sorted out. It will probably be a lot less expensive than continuing to buy parts as you destroy them. Or you could disconnect the alternator and put the battery on a charger when not using the tractor.
