Alternator for 6610S
   / Alternator for 6610S #1
M16
New Holland 6610S
Do they make an alternator that will fit the 6610S that doesn't need the battery temperature sensor. If so what is the model and where can I find one. I am having constant problems with the sensor and the battery doesn't get charged. A rat chewed the wires on my last one and they are 60 bucks to replace.
   / Alternator for 6610S #2
The temperature sensor is most likely a resistive device, and if you can find what the resistance should be for normal operation, you can just mount a regular resistor up by the alternator and it will think the temperature is fine.
   / Alternator for 6610S #3
Go to radio shack and buy a 200 ohm resistor and wire it in instead of the temp sensor.
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2015 INTERNATIONAL 28 PASSENGER HANDICAP ACCESSIBLE SHUTTLE BUS (A52577)
2015 INTERNATIONAL...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
