Alternator for 6610S
   / Alternator for 6610S #1
M16
New Holland 6610S
Do they make an alternator that will fit the 6610S that doesn't need the battery temperature sensor. If so what is the model and where can I find one. I am having constant problems with the sensor and the battery doesn't get charged. A rat chewed the wires on my last one and they are 60 bucks to replace.
   / Alternator for 6610S #2
The temperature sensor is most likely a resistive device, and if you can find what the resistance should be for normal operation, you can just mount a regular resistor up by the alternator and it will think the temperature is fine.
   / Alternator for 6610S #3
Go to radio shack and buy a 200 ohm resistor and wire it in instead of the temp sensor.
JOHN DEERE 9R640 LOT NUMBER 252 (A53084)
JOHN DEERE 9R640...
2012 TRAVIS 39FT DUMP TRAILER (A52576)
2012 TRAVIS 39FT...
2024 KMC 7406 (A53084)
City of Buckhannon - 2014 Ford Fusion SE (A52384)
City of Buckhannon...
2009 Freightliner B2 School Bus (A51692)
2009 Freightliner...
