Alternator/fan belt tension (L4200GST)
   / Alternator/fan belt tension (L4200GST) #1
Jay4200
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
My L4200's alternator/fan belt was running pretty loose - I also discovered that it is in horrible shape, but replacing it is for another day. At any rate, I snugged it up a bit, but didn't want to go too far and stress the alternator/fan pulley bearings. What should I use as a gauge to set the belt tension, and how tight should it be?
thanks - JayC
   / Alternator/fan belt tension (L4200GST) #2
This alternator is a relatively low output compared to a car... It dose not need to be as tight.
If you can turn, (slip) the alt pulley with a bit of effort by it's cooling fan it is tight enough. There is no need to stress the bearings. There is very little drag on the belt when putting out it's maximum. KennyV
2015 Ford Taurus (A51694)
2015 Ford Taurus...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
2007 CATERPILLAR 330DL EXCAVATOR (A51246)
2007 CATERPILLAR...
2002 INTERNATIONAL 4400 BEVERAGE TRUCK (A52576)
2002 INTERNATIONAL...
EZ-GO Textron Electric Golf Cart (A51694)
EZ-GO Textron...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
