alternator conversion massy 135
   / alternator conversion massy 135 #1
kayak
newport,TN.
67' MF 135
the generator armature shaft broke,so i'm going to change it over to an alternator,i just happen to have a spare alt. in the garage, i made all the brackets i need,and have it mounted on the tractor. i'm looking for a diagram or just an explanation on how to connect the alt.to the existing voltage regulator,or do i need to get a different regulator. i dont know where the alt.came from or what it fits. its a delco alternator with 2 post batt.,and grnd.,2 -1/4 in. spades marked "R"&"F".
   / alternator conversion massy 135 #2
Try this link. Tyler Woods explains it very well. I read his notes amoung others before doing mine. In my case I eliminated the voltage regulator because the alt had one built in. I also changed out the amp gauge to a volt gauge. I have a thread (link below in my signature) where I'm refurbishing my 135, (4 cyl gas version) mostly cosmetic which shows a few pictures where I modified the dynamo bracket. Take a piece if thick rope to check the length of belt you will need. It will be longer and got mine at autozone for few bucks. I aquired an alternator similar to yours but was equipped with a tachdrive on the rear to keep all my instruments functional.
BTW, if you need a hood and sides for your Perkins, I'll make you a good deal. I bought a new hood and sides and found out later that the Perkins and Continental hoods open on opposite sides. If I had knows this, I would have asked the question about the hood before purchase, so it was part my fault and didn't force the dealer to take it back.
Good luck on your conversion. If you have questions, at some point, we can help you out. -robert alias "the kid" :thumbsup:
Updating The Charging System of Your Older Tractor
2011 Ford F-150 4x4 Pickup Truck (A51692)
2011 Ford F-150...
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A53473)
2017 Ford F550...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
