alternator belt
/ alternator belt #1
offshorerivas
la blanca,tx
jd2040
morning
I have a jd2040 that the alternator belt can not be tighten further. it is at the end of the strap . the belt is not brand new but not a year old. the belt is from JD dealer
correct numbers on belt
/ alternator belt #2
Possibly wear on the pulley's over the years caused the belt to be loose? R73784 is the belt part no., right?
/ alternator belt
thanks for reply
jd catalog - # is t-20334 but now they sub #R97758 . the number you gave is different . lol now i am confused
thanks for help
/ alternator belt #4
1st thing that needs to be established is your tractors serial number & if your tractor has a 3 or 4 cylinder engine. Then the correct part number for fan belt can be chosen. Part # T20334 which subs to R97758 is for 2040 with 3 cyl engine below serial # 349,999. Fan belt for 2040 with 3cyl engine after serial # 350,000 is R73784. PS: I sold 2040 3 cyl tractors when they were NEW.
/ alternator belt
thanks tx jim
my tractor is under the serial #3449*999 ,maybe you tell me what the lever on right side under seat is.there are slots ,i belive there are 4 dents or holes
I am still new to tractors and learning . this is our 1st tractor thanks
/ alternator belt #7
R97758 is correct fan belt for 2040 <SN 349.999 with 3 cyl engine. Lever under seat is for draft control on 3 pt hitch. D=depth,L=load,L/D=setting in between L & D IE less sensitive than L
/ alternator belt
Tx Jim
this is offshorerivas with the 2040 loose alternator belt . the numbers on the belt are correct and go with the serial # under 349-999 what do you belive could be
the reason for the belt to be loose . It is tightened to the end of the strap .
thanks for your input
/ alternator belt #9
How many hours are showing on tractor speed-hour meter? Does the back of belt extend out past the belt pulley's when belt is installed? Have you checked number on belt not just on the cardboard holder?
/ alternator belt
the speed-meter does not work . the number on belt is correct for this tractor .
if i am understanding what you are saying the belt does not extend past metal strap that is used to bolt alternator when tightened . now that i am explaining this, could it be that metal strap was replaced with a different size.?
/ alternator belt #11
I'll rephrase my question. When belt is in the V of the pulley does back of belt sit level/above pulley or below pulley sides? Backside of belt below pulley sides indicates worn out pulley's thus belt won't be tight enough. If bottom of pulley V is shiny that a dead give away that belt is riding too far down in pulley & belt is slipping in pulley.
/ alternator belt #12
The substitution number is actually 1/2" longer than the original T20334 belt. Original belt is 48" long and R97758 is 48.504". According to Deere, the original is still available but it is only stocked in Germany. Should still be able to get it, but will take a while to ship. Ask your parts person to override the substitution and order the original number. Or you could source a 48" belt from auto parts store possibly. Width is listed as .688" and thickness at .406".
/ alternator belt #13
jd110
May I ask how you looked up the spec's for T20334? I understand if one enters part # in JD parts shopping cart then left click on part # in cart that part spec's can be viewed on some selected parts.
Thanks,Jim
/ alternator belt #14
jd110
Thanks,Jim
I wonder too. It seems more and more parts no longer have specs listed other than weight.
/ alternator belt #15
The dealer access includes a system called Parts Expert. It has more specs listed than system available to public. Many times if part is obsolete, the spec is wiped out from dealer view also. Since the T20334 is still available from European warehouse, the spec is still listed luckily.
/ alternator belt #16
jd110
So you have insider info! LOL Thanks for reply
Jim
2010 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2010 Ford F-250...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2016 Ford F-150...
2025 Auger Drill Bit Skid Steer Attachment (A64553)
2025 Auger Drill...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2025 58in Padfoot Vibratory Roller Skid Steer Attachment (A64553)
2025 58in Padfoot...
2020 CATERPILLAR 239D3 SKID STEER (A65053)
2020 CATERPILLAR...
