Alternator Battery Lug Thread Size ?
/ Alternator Battery Lug Thread Size ? #1
TimP
Platinum Member
Kingsville, MD
B3000HSDCC
Hi.
I'm in the middle of a ALternator Upgrade on my B2150.
The Kubota (Denso) alternator has a copper battery lug on the back of it.
I am supposed to connect the ring terminal at the end of my wiring harness to it.
But.. there was no nut on the alternator and no nut was included in the "upgrade" kit.
I have seen them on Alternator and they seem to be copper, but not always.
Does anyone have a clue what the thread size is on that lug so I can go searching for an appropriate sized nut to use ?
I assume since it's Japanese, it's a metric size.
If I had to guess... I'd say 10mm. But does anyone know for sure ?
Thanks, Tim
/ Alternator Battery Lug Thread Size ? #2
Tim, I just checked the 40 amp OE alternator on my BX2660. The nut that is under the rubber boot is 10 mm....can't say as to the thread specs other that it would be metric. The bolt that comes out of the back (under the boot) is copper looking, but the nut looks like it is stainless steel. Hope this helps. Mike
/ Alternator Battery Lug Thread Size ? #3
If a 10 mm wrench fits the nut,the thread size is M6 x 1.0,by far the most common size 6mm thread.Carry on!
Oldballs & number2,
Thanks for that info. 10mm M6 x1.0
I'll try to find the copper, but if not, SS will be the next choice.
Thanks again.
Regards, Tim
2002 Vermeer SC252 Walk-Behind Stump Grinder (A61572)
2002 Vermeer SC252...
1995 CUSHMAN TURF HAULER (A64280)
1995 CUSHMAN TURF...
2004 International 7400 C&C 017797 (A62613)
2004 International...
2019 KAUFMAN 46' STEP DECK TRAILER (A64280)
2019 KAUFMAN 46'...
1998 Ferguson 46B Compactor / Roller (A62613)
1998 Ferguson 46B...
KUBOTA RTV 900 UTV (A64280)
KUBOTA RTV 900 UTV...
