Alternatives to John Deere 110 TLB?
   / Alternatives to John Deere 110 TLB? #1
oifla
Looking for a 110 TLB for the following reasons: I like that it's a TLB, I like the ability to use skid steer attachments, and retain 3pt hitch / PTO for implements.
What other brands/models should I be looking for? I don't want to just slap a backhoe on a farm tractor. Thanks!
O.
   / Alternatives to John Deere 110 TLB? #2
O.
About the only other choice;
Kubota B21, B26, L35, L39, L45, L47, L48, M59, M62
Yanmar CBL-40
   / Alternatives to John Deere 110 TLB? #3
Yep, the JD110 was about the cutest TLB ever. You may want to skip down to the JD forum here on TBN and do search a few threads to get some idea of how used ones are holding up.
The other two in that same wt/hp/option class are both recent enough that you can find good examples of other brands/models with a little luck. They are the Yanmar CBL40 and the Kubota L39. Both are arguably heavier built and more durable than the JD110. None of the above have emissions controls. All had optional 3pt and PTO.
The Kubota L39 is no longer built - although Kubota still builds a smaller TLB and two larger TLBs. New TLBs are crazy expensive. Used ones are often ex-rentals. That L39 was a favorite, and had a model run from 2005 to about 2015. If you find one of those, grab it.
The Yanmar CBL40 model run was started about 2007 and there are rumors that there are some good onew ones till to be found.... but I've not seen one.
We were just talking about the Yanmar CBL40 on another thread & some data posted:
rScotty
Thanks all. I'd seen references to the mythical Yanmar that was like a JD110 but didn't have the model number. I'm adding that to the list.
O.
   / Alternatives to John Deere 110 TLB? #5
Just to be the weirdo;
   / Alternatives to John Deere 110 TLB? #6
Yanmar CBL-40
Yanmar CBL-40
I've got a Kubota L-47 and like it a lot. It only has appx. 350 hours on it and I use it mostly for backhoe/loader/fork/grapple work and have been very happy with it's performance. I did get the 3 point hitch kit with it but have not used that to this point.
   / Alternatives to John Deere 110 TLB? #7
I choose to buy the correct 4 point attachment to mount a backhoe on a tractor.
I remove it maybe twice a year when the tractor needs to do something else.
It digs as well as any TLB I ever ran but it has a short reach so moves are less than 9’.
So, for me anyway, having another motor with old leaky hoses to maintain for about 3 or 4 days of use per year-
Or,
Having another attachment that will serve my needs.
YMMV
   / Alternatives to John Deere 110 TLB? #8
A local small town just sold it's old full size JD310 backhoe/FEL. Our state requires that all municipal machines be sold at public auction. That well maintained old machine went for peanuts. Hope their new one works half as well.
That beats slapping a backhoe on a farm tractor, that's an inexpensive way to get a backhoe for occasional use, but it didn't have the SSQA or 3pt you are looking for. You still need a farm tractor.
   / Alternatives to John Deere 110 TLB? #9
I didn't know that the backhoe was removable on the Deere 110. I wonder how often that's done?
For my place, I bought a used 2WD New Holland 555E backhoe that's done everything I've wanted. I think it's better to have a dedicated digging machine, like a backhoe or excavator, then trying to do everything with just one machine. For almost 20 years, I just had the backhoe and a small 37hp tractor for mowing and 3 point attachments. I now have three tractors for doing farm things, but only use two of them. The small 37hp tractor has just been sitting for the last couple of years. I'm going to put the 6 foot cutter on it and use it for small areas, but with the 12 foot batwing on my bigger tractor, there's no rush.
Having the backhoe ready to go, anytime I need it is what makes it so useful. Trees fall down in the Spring from thunder storms. Animals pass away and need to be buried. Trenches need cleaning out so water goes where I want it from the storms. The backhoe is also very good at pulling me out when I get stuck!! But most of the time, I use it for digging out trees so I can increase the size of my pastures, of clear open areas for my fence. Trees too close to a fence will destroy it over time. My goal is to remove every tree that's 50 feet away from my fence. Having a backhoe means that I can do that when I have the time, and not have to change anything. I can mow one day, take out trees the next, or do both in the same day!!!!
   / Alternatives to John Deere 110 TLB? #10
Absolutely. The economic advantage to renting a backhoe as needed to dig ditches rather misses the point of having a hoe. It's not a tractor; it's something other.
For the farm or rural person with land, trees, and animals - having a backhoe right at hand for instant use as a combination mobile crane and digger saves a ton of time. Older used 2wd ex-industrial backhoe/loaders are powerful, cheap, and plentiful. For farm use they last forever. They are made to live outdoors, & can sleep behind the barn until needed.
Ours sleeps with a battery tender and a block heater on a thermostat. We start it a few times a year...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2016 Chevrolet Tahoe SUV (A52377)
2016 Chevrolet...
JOHN DEERE 460M LOT NUMBER 258 (A53084)
JOHN DEERE 460M...
Guard Rail Joints (A51692)
Guard Rail Joints...
2018 Challenger 1042 Tractor (A53342)
2018 Challenger...
