Alternative To Rear Remotes
   / Alternative To Rear Remotes #1
Ontario, Canada
Kubota BX25D
Hello all, I have just purchased a used hydraulic dump trailer (Berkelmans 2-ton Big Lil Dumper) to pull behind my Kubota BX. a 2021 Kubota KX-040 mini ex is suppose to land on my property in the next few months and the BX/dump trailer will be busy relocating a lot of material. The problem is - I have no rear remotes and no way to dump the dump trailer haha. As I can't see myself needing rear remotes for anything else, has anyone ever heard of using a 6 port - 4 function diverter valve to just re-direct flow from the loader bucket tip function to some long hydraulic lines going to the back of the tractor in lieu of remotes? Looking for a cost effective way to start dumping. I'm even considering just extending the trailer's hydraulic lines to reach up to the loader's hydraulic connections and just un-clip the bucket hydraulics to free up those ports when I want to move dirt - "dumping the bucket" would then dump my trailer. The BX would just be a tow vehicle at this point. Thoughts?
   / Alternative To Rear Remotes #2
I would consider a low end hydraulic 12 volt power unit...then it could be used with any vehicle that could tow it...
Power units are available from about $250...check Surplus Center...
   / Alternative To Rear Remotes #3
I think a single-spool rear remote is SOOO useful, and this may be your excuse to do it. However, a 12V power-pack, as SLASH recommends, makes the trailer independent, and that is also a good thing.
Plumbing from the loader would be a distant 3rd choice for me.
I should have mentioned - I definitely want the tractor hydraulics to do the lifting.
   / Alternative To Rear Remotes #6
Your idea will work, cheapest is to repurpose you curl circuit with some long hoses. However, I agree a rear remote is darned handy.
   / Alternative To Rear Remotes #7
Haven't looked for years, but IIRC, the BX loader valve is internal. The joystick is just a remote control for it. Kubota's optional rear remotes plumb into the transmission case.
Bruce
   / Alternative To Rear Remotes #9
Yes, but at some point there is a set of disconnects so the loader can be removed. Tie in there.
That's the least expensive way.
I just wanted to explain that there is not a loader valve at the bottom of the joystick.
Bruce
Okay you guys win - I went with remotes. They turned out awesome. I'll upload a video tomorrow.
- James
2008 Nautica International RIB 24ft Cat Boat (A50324)
2008 Nautica...
2010 Ford Taurus Sedan (A50324)
2010 Ford Taurus...
UNUSED AGT SKID STEER QUICK ATTACH SEEDERDRILL (A51244)
UNUSED AGT SKID...
TRAILER AXLE (A51244)
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
2014 Kia Cadenza Sedan (A50324)
2014 Kia Cadenza...
