alternative stump grinder idea
   / alternative stump grinder idea #1
shdybrady
ga
yanmar 1802
Just tossing around an idea in my head. Would you be able to fabricate a disc, drill and tap it to accept the stump grinder teeth. And possibly mount it on a 3pt post hole digger. Instead of the traditional stump grinder this would be more like a drill method but it would just grind it down. Do you think this would work>
   / alternative stump grinder idea #2
with enough tonnage over the tool, yes
   / alternative stump grinder idea #3
I don't think the auger would be strong enough to handle a very large ' drill bit'. The torq needed to turn an 18" hole in dirt broke our boom-to-lower link attachment, in wood, you'd be lucky to turn 6".
   / alternative stump grinder idea #4
I suppose you could use a drill bit like this on your post hole digger: the cone screw pulls the chisel wings into the stump.
https://www.youtube.com/watch?v=GIIGAXxOQFs
When it jams, i hope your tractor has the possibility of driving the PTO over the main gearbox like my Zetors have, so you can use the reverse gear to inverse the rotation of the PTO to unscrew it.
   / alternative stump grinder idea #5
Check out YouTube. These exist in Europe.
   / alternative stump grinder idea #6
Maybe put a stickler on the PTO shaft?
Then you could "drill" down and split it to pieces.
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A51692)
2013 International...
2008 Chevrolet Suburban SUV (A51694)
2008 Chevrolet...
2015 Ford F-450 Flatbed Truck (A51692)
2015 Ford F-450...
2015 Ford F-450 Knapheide Service Truck (A51692)
2015 Ford F-450...
UNUSED FUTURE QUICK ATTACH MAST W/ 29" FORKS (A51248)
UNUSED FUTURE...
2014 Ford Escape SUV (A51694)
2014 Ford Escape...
