Alternate blades for LT-1000 series
   / Alternate blades for LT-1000 series #1
texstrk426
Tioga, TX
John Deere 5105
I noticed a thread regarding deck belts jumping off the idler pulley. One comment mentioned the mulching function of the blades contributing to grass mat buildup above the blades. Are there any alternate blades that promote better ejection of cut grass from the right discharge duct and less mat buildup under the deck? My unit is a LT-1050. Thanks in advance.
   / Alternate blades for LT-1000 series #2
buy yourself a set of bagging blades with extra high lift,have had quit a few probs with belt jumping of 50" decks try some belt guards on idler pulleys see if that helps
   / Alternate blades for LT-1000 series #3
op - in the springtime with high moisture content grass clippings, best bet is to scrape that deck underside a bit more often. PITA, yes, but will help.
TMA (A49461)
TMA (A49461)
377811 (A48836)
377811 (A48836)
New/Unused 75in Skid Steer Soil Conditioner (A51573)
New/Unused 75in...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A53472)
Ditch Witch 6510A...
