alt not charging on 12 volt conversion
   / alt not charging on 12 volt conversion #1
charlton289
Hurt Va.
2016 massey ferguson GC 1705
I m trying to figure out how to hook up the wires to and from alt it has alt and it does run but will not charge I have put a charger on or jump after it runs for awhile. Or after repeated starts does anybody know how to run wiring and if I need a voltage regulator
   / alt not charging on 12 volt conversion #2
need to know what type of alternator it is (ford, chrysler, GM) is it internal or external regulator, or is it a generator? have any pictures?
its a delco not sure of model but has battery and two connectors 1 and 2. I have pictures but I don't know how to post pictures here. I have been trying to look for diagrams I found everything but what I need for a 55 ferguson to35 any help is greatly appreciated thank you.
   / alt not charging on 12 volt conversion #4
Click on the picture of the tree above the reply box, third from the right to insert picture. Tomorrow I can check our 54 To-30.
   / alt not charging on 12 volt conversion #5
SI internal regulator 3 wire hookup ...
BAT post to the big wire to the battery
small jumper from BAT to pin 2
a wire from the ignition post on the ignition switch ( live when you are in RUN position) goes through a small 12v side marker light and then to pin 1
light is ON when the ignition is ON and the alternator is NOT charging ... goes out when it is charging
other people skip the bulb and use a diode in place of the bulb ... white end points towards the #1 pin on the alternator
Truck Metal Cargo Storage Box (A55787)
Truck Metal Cargo...
2019 CATERPILLAR 305E2 CR EXCAVATOR (A52709)
2019 CATERPILLAR...
2018 Caterpillar 308E2 CR Midi Excavator (A55973)
2018 Caterpillar...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A56435)
2023 Kubota L3560...
ENCLOSED DRIVING SIMULATOR TRAILER (A58214)
ENCLOSED DRIVING...
TEST YOUR BID BUTTON! (A52709)
TEST YOUR BID...
