Almost Rolled the New Holland Yesterday
   / Almost Rolled the New Holland Yesterday #21
We built a huge retaining wall down in a ravine last year and used our TC35DA with factory loader to move at least 9 tandems of "fill dirt" . I backed each loader full of fill to bottom of ravine . Tedious but safe and not to mention having the machine under control. The hydros made it fun also . It is amazing the amount of materials we have moved with our little bruin. Another thing is in hot weather I only run 1500-2000 RPM ,this machine is loaded with low end torque. Going on 600 hrs of hard core landscaping and haven't phased this tractor.
   / Almost Rolled the New Holland Yesterday #22
Larry_NFES said:
I personally remove the loader during mowing work but I have a sub-compact and just a few rolling hills which I save for the small rider or push mower.
I mow the wide open spaces of my 2.33 acres with a Kubota BX23 with the 60'' mmm .I've never had rhe FEL or BH off it.
For the smaller tighter close in areas I mow that with a Kubota Bx1500 with a 48'' mmmm.
   / Almost Rolled the New Holland Yesterday #24
KubotaSteve said:
I almost always take my FEL to mow. The tractor is much more stable without the loader on it. I did an experiment once by seeing how the tractor felt when mowing with and without FEL. I could go on the side of a bank and the tractor felt more stable without the FEL then with it on. It is much smoother mowing without the FEL plus the time I save makes up for the few minutes taking the FEL off. Now if I'm using rotary cutter, I leave the FEL on. You should try mowing without the FEL on once.
I don't have a fel for my BX1500s but I mow with a 48'' mmm on one of them.
2019 JOHN DEERE 843L-II FELLER BUNCHER (A51242)
2019 JOHN DEERE...
UNUSED AGT YSRT14 STAND ON SKID STEER (A51243)
UNUSED AGT YSRT14...
2018 Nissan Versa Sedan (A50324)
2018 Nissan Versa...
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
48in Forks Loader Attachment (A49346)
48in Forks Loader...
2018 CATERPILLAR 305E2CR EXCAVATOR (A51242)
2018 CATERPILLAR...
