Mowing Almost rolled it- dumb, stupie, smart
   / Almost rolled it- dumb, stupie, smart #11
I'd venture to say that just about all of us that have used our tractors for more than just mowing level lots has had some "browning of shorts" experiences.
Something as common but unexpected as riding over a good sized surface tree root can give you that roller coaster in the pit of the stomach feeling.
Yes, the FEL off is better on hillsides or always keep it low.
See, I would figure you're better off with it on, assuming you keep it as low as possible. Then again, I don't have a mower on my BX25.
   / Almost rolled it- dumb, stupie, smart #12
Couple of "lessons" I didn't see mentioned;
1) The inherent risks of working on someone else's property.
Whether or not for gain/profit it is very unfamiliar and just about any dump spot will become overgrown eventually and appear "mow_able".
2) New tractor, this just compounds the risk.
New or just new to you, either way.
3) The distinction between tractors and mowers.
There really ARE low built machines for this.
Tractors can mow, but they are Swiss Army knives.
They present compromises, just as a real screwdriver is easier to use and less likely to slip and gouge your other hand.
Not to be hypercritical and I'm really pleased you got away with this.
Oh yeah, backing out of trouble is usually a better option than more of what got you into trouble.
If you have a loader on - usual rule; low enough to see over it, not high enough to see under it (-:
Keep the bucket fully rolled forward, if you have to use it as an emergency brake and then as a reverse gear it will slow you better than the flat bottom of a curled bucket and be ready to push you back.
Don't worry about tweaking the loader arms, in an emergency Ya gotta stop when Ya gotta stop.
That is a good tip about keeping the bucket rolled forward.
Totally hear ya about working other properties. It was a combination of favor and self-defense, since this is fire country and they aren't getting it done.
I have a regular garden tractor mower and yes, they are vastly superior for maneuvering around the house. Also a much neater cut than a tow behind rotary kutter. However, that thing is lost in the pasture or their neck-high weeds.
I will just stay further away from edges of all kinds over there. My goal is just to clear the wide expanses of tinder, and the trim is their problem.
More projects to follow. Just gotta put it behind me and store the lessons.
   / Almost rolled it- dumb, stupie, smart #14
All you were doing was fine tuning the rear cheek clench factor tipping gauge. Now you know what it feels like to almost roll it, next time you'll know when your getting close.
I fine tuned mine the first time i really used my FEL, had to get a friend hiking out on the outboard rear tire.
   / Almost rolled it- dumb, stupie, smart #15
Dave, for what it is worth.
3 things from someone who does the things you described a LOT
1: when you have to winch/pull someting out of a hole, pull from the low front side, NOT the high! You will save yourself a LOT of damage pulling from the low front side.
2: Yeah, "back out" the same way you went in. the Big wheels are way better at getting you out of trouble than the little ones are.
3: Loader on? bucket curled all the way UP! and "feeling the ground, brail style". If your bucket is curled all the way down and you hit a stump or other immovable object you risk blowing out a hydraulic line. Pull THAT stunt in a precarious location and the tractor will let you down big time. I do not mow with a loader on. it severly hurts manuverability.
I mow a LOT of acreage in mountain country. In fact less than 10 % of my hunnert+ acre property is "flat" ground. I have had enough "brown alert" moments for a lifetime!
Lastly your front axel moves for a reason...... watch it like a hawk, cause the rear axel ain't gonna be so forgiving!
   / Almost rolled it- dumb, stupie, smart #16
1 more lesson to learn here.
When sliding sideways, using the rear diff lock will only make it slide MORE sideways. I know it's tempting, but stay off the rear diff lock when sliding sideways, or when sliding sideways would be bad. That's when having 4wd is nice.
I'll agree on mowing without the FEL. In fact, I like mowing with 0 extra weight on the front end. This past weekend, I needed to add some weight up front for something I was pulling. After that was done, I didn't bother removing the 150 lbs of suitcase weights before mowing. Because the extra weight up front took weight off of the rear wheels that don't pivot, and put it on the front axle that does pivot, the tractor was much less stable, even though the suitcase weights were only approx 6 inches off of the ground, and nice and wide.
   / Almost rolled it- dumb, stupie, smart #17
I got my FEL in a crate almost 9 months after getting the tractor. Installing was difficult, only because I wasn't up to speed on many things. Once I had it on, I had to work the garden. One time with the FEL was enough. No way. The loss of being nimble was intolerable. OK, what to do?
Sounds funny to say now, but I played those Messick and BXpanded youtube videos over and over until I could master the removal and installation of the FEL. I was determined to get quicker and I practiced. No, I still cannot do it as quickly as BXpanded or Messick, but it only takes me 5 or 10 minutes, which is good enough.
I think one of the things we could/should encourage all the "I just got my new tractor" posters is strongly encourage them to master this skill. All these new guys are so geeked to have their FEL, but it just has to come off from time to time, for safety and for practicality.
   / Almost rolled it- dumb, stupie, smart #18
Another lesson to learn: Before mowing unfamiliar ground, walk it on foot to see what's there.
   / Almost rolled it- dumb, stupie, smart #20
I'm not sure I agree with this. He's using a rotary mower not a MMM.
Quote:
Originally Posted by rekees4300
Lesson not learned: Remove FEL before mowing.
I should have said "Remove FEL before mowing slopes". Nevertheless even on level ground removing the FEL will increase stability and reduce front axle stress.
2007 Freightliner M2 106 Medium Duty Pac-Mac RL10 10 Yard Refuse Garbage Truck (A55852)
2007 Freightliner...
2020 CATERPILLAR 908M WHEEL LOADER (A52707)
2020 CATERPILLAR...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
UNUSED FUTURE SF60 60" HYD SIDE SHIFT FORKS (A57193)
UNUSED FUTURE SF60...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2013 Chevrolet Caprice Sedan (A56859)
2013 Chevrolet...
