allowed pushing with box blade
   / allowed pushing with box blade #11
And I have welded and straightened in a press, many a lift arm. Never mine, but for others. Pushing with a box blade backwards was the cause of the last few breakages.
Bending an arm with traction force alone would be pretty rare. If they’re ramming stuff all bets are off.
   / allowed pushing with box blade #12
Really, I've pushed with my boxblade about as much as I've pulled with it over the 25+ years I've had it on two different tractors. What has ALWAYS "given" on mine are the drawpins on the boxblade - they bend before anything else. I always keep a couple spares in the toolbox. They also bend going forward if I grab something that doesn't want to move. Many times I've been able to straighten the pins with a 10 lb. sledge and keep on going, after a time or two of that I usually replace it - $3 -$4 each at the Co-op.
   / allowed pushing with box blade #13
a really bad idea. not what 3 points are designed for.
in fact the front bucket really isnt designed for pushing either. we all do it some of us are more careful than others.
   / allowed pushing with box blade #14
I can push with the front or back of my 4' box blade:
Turned around, pushing with the back:
   / allowed pushing with box blade #15
I was gifted a 6' box blade that had bent and lose cat 1 pins so i broke out the wrenches and a big A$$ pipe wrench, replaced them after a lot of shouting in french. was very proud of myself as i used my new (to me) box blade with bright n shiny cat 1 pins in it as a counter weight while digging out my pond until i backed into the bank and promptly bent the heck out of one of my new pins.
   / allowed pushing with box blade #18
I operated a 9k telehandler with a 45’ reach last month for a couple days while setting steel for a new barn. It was my first experience in one. They are awesome machines, but backing up without a camera required some forethought and a little bit of memory. The mirrors provided a limited view. So, I totally can appreciate why you adapted the blades to push instead of pull. Very cool. It’s hard to imagine how awesome the telescoping is without experiencing it. Now I wish one of my tractors had a telescoping loader.
   / allowed pushing with box blade #19
That is why I have a rear view camera:
And 7" monitor:
   / allowed pushing with box blade #20
I think you are in the same boat as I with heavy 3pt lift arms and stabilizers, our 3pt hardware is tougher than the cat 1 pins, some others might not be so lucky, the 5145 is cat1/2. after bending my new cat1 pins i thought i would just upgrade to cat2 but after some better thinking i realized that right now the cat1 pin is the fuse and i might want to keep it that way. i'm the same way on my grapple, i went with light duty to start with (not having an FEL on past tractors) until i get some practice so i do not tweak my FEL.
2004 STERLING LT9500 SERIES MIXER TRUCK (A50854)
2004 STERLING...
MAGNUM PRODUCTS LIGHT TOWER (A50854)
MAGNUM PRODUCTS...
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
Drill Bit attachment (A50322)
Drill Bit...
TMA (A49461)
TMA (A49461)
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A49461)
2012 Vermeer...
