Allowable play on backhoe/fel mounts
/ Allowable play on backhoe/fel mounts #1
kjbpe
I thought the kubota l48 I bought was routinely greased. Every joint had no play in them. But...when I greased all the joints (four needed the pins removed and the grease channels cleaned out) I noticed some play in the backhoe and fel pivot joints. My question is: how much, if any play is acceptable? It appears to be about a 3/16" movement across the end caps. Is this normal for a machine with 600 hours and will it get much worse?
2003 McCormick XTX 185 XtraSpeed Tractor (A63688)
2003 McCormick XTX...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
2018 CATERPILLAR 232D SKID STEER (A64279)
2018 CATERPILLAR...
2016 WEILER P385A ASPHALT PAVER (A63276)
2016 WEILER P385A...
Ford F-450 (A63689)
Ford F-450 (A63689)
2012 INTERNATIONAL 4300 4X2 S/A 18FT NON CDL BOX TRUCK (A59912)
2012 INTERNATIONAL...
