Allmand TLB
/ Allmand TLB #41
I would think that the way it is setup in your situation is so the machine uses those two lines coming from the gear pump as both to/from depending on which way you are steering. Leaving the tank line to only let a little bit of fluid release when a shock is given to the system, as in steering left and all of a sudden wheel hits a rock giving the steering a jerk. Similar to how the drive motor would be. I have nothing to back up this line of thinking though other than common sense so I could be way off.
My other thought would be one in line and one out line, and the remaining line being for the load sense. It may just give feedback to the pump so it can decifer the demand needed from the pump. I don’t believe my allmand has the load sense.
/ Allmand TLB
Thanks for the replies, the new pump has shipped and should be here in a day or so.
/ Allmand TLB #44
Congrats. Who makes tge pump and the parts number please
/ Allmand TLB
This is an email reply if you need more info feel free to ask.
On Feb 24, 2022, at 12:40 PM, Marnie Emrich wrote:
The replacement is built with current Eaton 26000 series parts but there is no official Eaton part#, only our part# CSE14927.
Parts are available as long as supported by Eaton for the 26000
series It is the same as the original aluminum with cast iron housings.
/ Allmand TLB
I called the rental company that originally sold it to the fellow I purchased it from and they said they sold it because the back of the pump had a crack so the guy I got it from said he replaced the back part of the pump with a used one but could not get it working properly so I purchased it and went from there.
/ Allmand TLB #49
I got mine pretty much the same way. The thick plate that the backhoe swing cylinders attach to was broken. I paid $8000 for my 535. Made it back the first yr I owned it.
/ Allmand TLB #50
How much you think one of these would sell for these days? I’ve been really tempted lately to sell it and pick up a newer mini excavator
/ Allmand TLB
A gasser would be around 10,000 up and diesel a couple thousand more
/ Allmand TLB #52
Ive seen them selling as high as 20k but sat. For a long time. If i try to sell mine i would want to walk away with 12k min. Mine works 100% with no issues. I wanted a mini ex also but its so nice only having to bring 1 machine to a small job. I can plant trees and move soil wirh the hoe.
/ Allmand TLB #53
I’m in the same exact boat. I know in general people love to think the diesel is so much better than gas but I personally don’t think it makes much of a difference when spinning a little hydro pump. I could see a little less value there in the eyes of some people but I would just get someone digging on the tractor if they were interested in purchasing it and they would forget all about questioning if it has enough power or not. I tend to do a lot of couple yards of material kind of jobs run it out to the backyard and love always having the backhoe there for an option if something needs to get dug up. If I end up leaving my full time job I would then switch to a mini and trackloader but for now I’m thinking I’m gonna ride it out with the allmand because of its versatility.
/ Allmand TLB #54
You can almost buy a new gas engine for just the cost of an injection pump on the diesel.
/ Allmand TLB #55
It’s a nice feeling to know if I blow the motor in mine it’s a $600 fix for a new engine. The engine nor horsepower are the limiting factor on these tractors. It lifts the same amount. Goes the same speed. Pushes into a pile til losing traction. Starts every time whether 100 or -10 outside. Can fuel up without smelling like said fuel all day lol
/ Allmand TLB
I like the diesel because my tractor is diesel, mower is diesel so the only gas I need is about 2 gallon of 2 cycle per year.
/ Allmand TLB #57
Gas or diesel, beats the blazes out of a shovel and wheelbarrow.
/ Allmand TLB #58
Makes sense, I have a gas truck at the moment which is same kinda methodology as you, gas tractor, truck and equipment so no one messes it up lol
/ Allmand TLB #59
Installed new pump and she is working like new again.:):):)
Why did you have to buy a new pump? Couldnt get parts for the old one? I have an Eaton 26000-500C on my 2005 325 TLB...load sensing is shot and overloading the engine / stalling it. I just started to look for parts...tlbparts.com doesnt respond/pick up the phone. Have you found a dealer or distributor where you can buy the load sensing resealing kit?
/ Allmand TLB
I replaced the pump after a rebuild kit only got me another 200 psi which didn't help.
I have a valve for the steering circuit from the pump
2005 Mack CL713 Truck (A60352)
2005 Mack CL713...
14in Digging Tooth Bucket Excavator Attachment (A64194)
14in Digging Tooth...
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
Caterpillar 12H/140H/160H Motor Graders Service and Parts Manuals (A63117)
Caterpillar...
(2) HARROW DRAGS FOR WINGS (A63291)
(2) HARROW DRAGS...
2017 Kia Cadenza Sedan (A61574)
2017 Kia Cadenza...
