Allis, Ford, Kubota, JD, Kioti...
   / Allis, Ford, Kubota, JD, Kioti... #1
CBB
Just north of the PA line in NY
JD 5320N Vineyard, 1981 Deere 910, 1980 Kubota B22, 1983 Ford 1710
1953 Allis-Chalmers B
???Ford Jubilee
1981 Ford 1700 4 x 4 Gear
1990 Kubota Compact
1993 Kubota 4 x 4 w/ Backhoe and Front Loader
1996 John Deere 990 Gear w/ Front Loader
2006 Kioti CK 20 w/ Woods Backhoe, Front Loader, Cab.
This is the list of tractors I grew up with. The Allis was something. If you were pulling a heavy log and foot slipped off the clutch, the front end would come right over on you. It had brakes but they seldom worked and never worked going backwards. But it ran well, hauled wood and would run on homemade fuel, if you wanted it to.
The Jubilee was two wheel drive but a huge step up from the Allis. It broke through the ice and took a swim but after draining the oil, kept on running…until it burned up in a barn fire.
The Ford still runs today. It was a no frills workhorse that reminds me of the dependability of today’s Kioti. It was the first 4 x 4 we had. The engine is tired with 1800 hours on it and it needs a rebuild but everything else works like the day it was bought and it has never broken down. Running out of fuel was a pain.
The JD 990 has 600 hours on it and is old before it’s time. It works okay but the brakes squeak, the gears grind a bit, the hydraulic pump has never really been big enough but it still was a lot nicer and more powerful than the Ford 1700 except it won't last as long without a lot of maintenance.
Oh, the 1993 Kubota…That darn tractor is broken more than it works. The control arms on the backhoe are always rusted and broken and when you take them apart to fix them one will marvel at the lousy craftsmanship. The engine and clutch and parts…it just has been a bad tractor. It is my brothers and right now, it is sitting as usual with the hood off. He will get it going and it will work that day but be a pain in his behind shortly there after. The dealers fix it but it just sucks.
The Kubota compact…just runs and runs. We bought it for the MMM but that was a lousy setup and so we just had that deck, which we took off the first year, hauled away for scrap. We use the 3 pt. hitch and PTO for little jobs, like spraying down narrow rows but it is only used a few hours a year.
The CK 20…nice machine. There are 20 hours on it, 2 of which are mine. A very “safe” machine with all the safety features….the opposite of the old Allis. The HST is nice but what is all that hissing noise? The hydraulics are well matched to the bucket and the backhoe is really nice. I like the cup holder. Need a place to put a shovel. My dog fits at my feet just fine and is content. The heat on the floor seems excessive? First impression, I like it!
   / Allis, Ford, Kubota, JD, Kioti... #2
I don't really find the heat on the floor excessive, but there are hydro hoses running under the platform, and you do get some heat from the side venting exhaust, but that's not a problem for me at all.
The "hissing" noise to which you refer is simply HST noise from the hydraulics working. You'll quickly come to listen to that and know things are sweet. If you hear a change in the sound, you'll know to investigate for why.
John
   / Allis, Ford, Kubota, JD, Kioti... #3
</font><font color="blue" class="small">( The heat on the floor seems excessive? )</font>
I owned one tractor that would practically melt your left foot when mowing on summer days, and it was a JD 4600. I literally had to cross my left foot over to the right side when mowing or it was unbearable. Unless your CK20 melts your shoe, it's not nearly as hot as what my JD 4600 was. /forums/images/graemlins/crazy.gif
</font><font color="blue" class="small">( </font><font color="blueclass=small">( The heat on the floor seems excessive? )</font>
Unless your CK20 melts your shoe, it's not nearly as hot as what my JD 4600 was. /forums/images/graemlins/crazy.gif )</font>
The heat is not that bad and did not bother the dog who was laying on the floor by it. I still may engineer a sheld for the blowing air though.
Shovel...got to figure out a place for it.
   / Allis, Ford, Kubota, JD, Kioti... #5
You've had quite an assortment and I enjoyed your assessment of each one. I've only had four, a Farmall H, Ferguson 30, JD 870 ,and now the Kioti 45. I am a bit surprised about your 990 comments, my 870 was a great tractor with zero problems and would still be here if I hadn't needed a bit more hp for field work.
</font><font color="blue" class="small">( my 870 was a great tractor with zero problems )</font>
I think the 600 hours on the JD 990 were tough hours. It is a nice tractor but does need some TLC. But I would not say it was a great tractor.
2008 Ford F-450 Crew Cab Service Truck (A52377)
2008 Ford F-450...
New/Unused Gold Mountain Container Shelter 20ft x 40ft (A51573)
New/Unused Gold...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A52576)
2020 INTERNATIONAL...
2017 Big Tex 10ET T/A Flatbed Equipment Trailer (A50322)
2017 Big Tex 10ET...
2019 John Deere S780 Combine (A53342)
2019 John Deere...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
