Allis Chalmers WD & WD 45 rims
   / Allis Chalmers WD & WD 45 rims #1
dieseldude
Northern Virginia
B7610
Does anyone know if rear rims from a wd45 will fit a wd?
Thanks
   / Allis Chalmers WD & WD 45 rims #2
Yep,almost any part will work for one to the other
   / Allis Chalmers WD & WD 45 rims #3
I believe those same rims will also fit the D-Series tractors.
I am almost positive they will fit fit a D-15, maybe a 14, 12 and 10 not sure about a 17 or not.
Have you ever been to the Unofficial Allis website:
http://www.allischalmers.com/
The rims are inverts of a Massey Ferguson 135 with the PAVT wheels. Only reason I know that is because we cut a section of and old WD-45 rim out of an old rim and welded it into a 135 wheel that was BADLY rusted.
   / Allis Chalmers WD & WD 45 rims #4
</font><font color="blue" class="small">( I believe those same rims will also fit the D-Series tractors.
)</font>
The holes that bolt the wheel to the hub might line up but the rims aren't all the same diameter as factory equiped. the WD and WD45 have 28" rims. The D15 and D14 have 26" rims. The D10 and D12 have 24" rims. A D17 has 28" rims and is very similar to a WD45 in many ways.
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2014 FORD F-150 (A52472)
2014 FORD F-150...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
2024 New Holland T8.410 MFWD Tractor (A52748)
2024 New Holland...
2006 UTILITY VS2RA 53 FT REEFER TRAILER (A52577)
2006 UTILITY VS2RA...
John Deere 6120E (A50323)
John Deere 6120E...
