allis chalmers tractor
   / allis chalmers tractor #1
schalfback
I have a 712S tractor. Looking at the rear it appears it has two what could be hitches. One has linkages going to it like it is for a lift set up for maybe a plow etc. Does any one have a 712S with this set up? Any info would be appreciated.
   / allis chalmers tractor #2
What you are looking at is a unique type of 3-pt hitch similar in use to a CUT, SCUT, etc. The round tube at the top provides the "lift" for rear attachments, rather than simply a toplink on a CUT/SCUT. The bottom hitch points hold the attachment in place, and work like sway-bars or stay chains to keep if from swinging side to side. You can get what's called a "sleeve hitch" or a "Brinly hitch" that pins into the bottom two points and allows use of common aftermarket attachments such as moldboard plows, cultivators, etc.
Suggest you go to http://simpletractors.com -- a site dedicated to these old machines. You can find out all kinds of helpful info there including all the attachments for them, ways to get manuals for them, etc.
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A52576)
2003 FONTAINE...
378789 (A51572)
378789 (A51572)
FIRESTONE 9.5L-15 4 RIB TIRES (NEW CONDITION) (A52748)
FIRESTONE 9.5L-15...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
2011 FREIGHTLINER CORNADO (INOPERABLE) (A52472)
2011 FREIGHTLINER...
