allis chalmers tractor
   / allis chalmers tractor #1
schalfback
I have a allis chalmers 12 hp model 712s. Everything works but the mower. When I try to engage the mower the motor stops and thats it! I just got the tractor with no info.Can any one help me on how to engage the mower properly and what to start looking for if I have a problem.It worked when I bought it 8 months ago. HELP
   / allis chalmers tractor #2
With the engine shut off, can you reach under the deck and turn the blades? Sounds like it could have a grass clump or a frozen bearing in one of the deck mandrels.
   / allis chalmers tractor #3
If you check what billbill said and the deck is "ok", check the engine set up. Sometimes it may need a tuneup. It will run without the deck disengaged but it won't run when the drag of the deck is added.
   / allis chalmers tractor #4
I agree with the Bill that chances are that a bearing frooze up or you have a foreign object of some sort blocking the blades from turning. There is not that much to that model tractor to go wrong.
   / allis chalmers tractor #5
I'm thinking that you need to look under the seat at the safety switch to see if it's properly wired up and corrosion free.
NPK GH-9 Excavator Hammer (A50774)
NPK GH-9 Excavator...
2018 GMC Sierra 2500 4x4 Crew Cab Pickup Truck (A50323)
2018 GMC Sierra...
New 20x20 Steel Carport (A50774)
New 20x20 Steel...
3 PHASE SEPARATOR (A52472)
3 PHASE SEPARATOR...
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
Generac Generator (A50774)
Generac Generator...
