Allis Chalmers no-till coulter rubber spring replacement
   / Allis Chalmers no-till coulter rubber spring replacement #1
awhite
Southwest Virginia
Kubota M6800/Kubota L3830/MKubota M8560 CAB/Kubota ZD221/Kubota BX1500/Ford 3930
I'm in the process of replacing the rubber springs on our Allis Chalmers planter. Just wondering if anyone else has had any experience doing this. There seems to be a pin that needs to be removed to seperate the rubber spring part from the coulter frame. I've found a parts blowout from Agco but I'm not still not exactly sure how to approach it. Any help is appreciated!
Pin is referenced as 20:
   / Allis Chalmers no-till coulter rubber spring replacement #2
where did you find the new rubber spring? was it difficult to replace , I have the same planter/coulter and coulters are useless because torsion springs have dry rotted
   / Allis Chalmers no-till coulter rubber spring replacement #3
Yoy can get them at allis chalmers dealer bur they high as hell
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
Rubbermaid Water Trough - 100 Gallons (A55218)
Rubbermaid Water...
2012 JOHN DEERE 410K BACKHOE (A51406)
2012 JOHN DEERE...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52705)
2014 CATERPILLAR...
2012 DOOSAN G25 GENERATOR (A53843)
2012 DOOSAN G25...
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
