Allied Loader question
   / Allied Loader question #1
Smokin50
Long 510
I have an Allied 380 loader, when I tilt the bucket all the way down and drag backwards, the bucket does not maintain position. If I hold the control handle down it will pressure up and hold in the down position. Same thing happens when I try to dig with the bucket, wont stay down unless I hold the control down while digging. Just changed the control valve, didn't help that problem. Any suggestions would be appreciated. Joe
   / Allied Loader question #2
Are you sure the valve lever is going back to neutral, and shutting off the flow to the cyl.
Do you have float?
Not sure about float, brand new oc valve
   / Allied Loader question #4
When you push the lever fwd all the way, does it detent, and stay in place. Does the bucket float on the ground rising and falling with the lay of the land?
Most tractor loader valves will have float.
When you set the bucket, either up or down, it should stay set until you move the valve lever.
You should be able to raise the front wheels off the ground using down force, and remain there for a good while.
2016 John Deere 5055E 55HP Utility Tractor (A52377)
2016 John Deere...
2014 Peterbilt 337 Service Truck (A53422)
2014 Peterbilt 337...
2018 INTERNATIONAL LT625 (A53843)
2018 INTERNATIONAL...
2013 Nissan Juke SUV (A51694)
2013 Nissan Juke...
2011 Honda Pilot EX SUV (A53117)
2011 Honda Pilot...
2005 Ford F650 SVI Crew Cab Hazmat Truck (A52377)
2005 Ford F650 SVI...
