Allied 295 Loader - Lift Cylinders Leak
   / Allied 295 Loader - Lift Cylinders Leak #1
bbfarm
Pacific NW
2002 - Kubota L3710 HST
Had the tractor out after a long hibernation.
The lift arms on the loader are leaking. Before they would weep a little. Not at the seal & rod, but at the gasket where the the collar threads into and snugs up on the cylinder.
I'd like to torque it down with a pin wrench. It's 2 1/2" Cylinder. Spacing between the holes is ~ 2 1/8". Pin diameter is about an 1/8"
Where can I purchase a Pin Wrench? It appears nowhere in my vicinity. I'd like to think that if I can snug that collar up, the gasket will stop leaking.
This Loader was Mfg in 1999, does Allied/Buler use generic hydraulic cylinders. Would anyone know who's make. I sense a new seal kit is the next step.
   / Allied 295 Loader - Lift Cylinders Leak #2
It won't help to do what you want! Better to find a good hydraulic shop or dealer and they might have the generic packings to rebuild it in stock.
   / Allied 295 Loader - Lift Cylinders Leak #3
Pix??
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2000 GMC C7500 CRANE TRUCK (A51406)
2000 GMC C7500...
30in Forks and Frame Mini Skid Steer Attachment (A51691)
30in Forks and...
2025 CFG Industrial H15R (A50123)
2025 CFG...
2005 Ford F-750 Crew Cab Heil 5 Yd Mason Dump Truck (A51691)
2005 Ford F-750...
Rogator New Leader RG1100 (A50123)
Rogator New Leader...
