Allied 295 Loader - Lift Cylinders Leak
   / Allied 295 Loader - Lift Cylinders Leak #1
bbfarm
Pacific NW
2002 - Kubota L3710 HST
Had the tractor out after a long hibernation.
The lift arms on the loader are leaking. Before they would weep a little. Not at the seal & rod, but at the gasket where the the collar threads into and snugs up on the cylinder.
I'd like to torque it down with a pin wrench. It's 2 1/2" Cylinder. Spacing between the holes is ~ 2 1/8". Pin diameter is about an 1/8"
Where can I purchase a Pin Wrench? It appears nowhere in my vicinity. I'd like to think that if I can snug that collar up, the gasket will stop leaking.
This Loader was Mfg in 1999, does Allied/Buler use generic hydraulic cylinders. Would anyone know who's make. I sense a new seal kit is the next step.
   / Allied 295 Loader - Lift Cylinders Leak #2
It won't help to do what you want! Better to find a good hydraulic shop or dealer and they might have the generic packings to rebuild it in stock.
   / Allied 295 Loader - Lift Cylinders Leak #3
Pix??
Kubota M6800 (A50123)
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A53426)
2014 HINO 338 26FT...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
2005 International 4200 VT365, Super Cab (A52384)
2005 International...
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
