Allergic to my tractor?
/ Allergic to my tractor? #21
Vicar mentions "recently snow removal with FEL", why would natural allergens bother him during a Connecticut winter? Shouldn't they be locked under the snow/ice? I'd try out the smoke stack, I rarely notice the fumes from my tractor's stack unless the wind blows just right. If he tries a mask he will not get the issue narrowed down. Either way it must be figured out so he can have seat time without discomfort :)
/ Allergic to my tractor? #22
You might have something there.... it could be too much CLEAN, FRESH AIR! :D
I agree, the suggestions to extend the stack upwards will help isolate that from being a potential cause.
Driving around with a respirator on ... especially in the summer ... would take the fun out of tractor work in a hurry.
/ Allergic to my tractor? #24
bx23barry said:
Rather than playing around with the exhaust or masks, if you are happy with the BX size and power just trade it in on a gas powered MF. You may even come out money ahead. ;)
SACRILEGE!! :( :(
/ Allergic to my tractor? #25
I thought it was just me. My sinuses were irritated within the first hour on my L3400 last winter.
It got better in the summer, so I suspected one of two things: Either the winter additives were what was really bothering me or the fuel may not have been burning efficiently because it had been sitting around so long. My first tank lasted me 4-1/2 months and was probably old when I got the tractor, whereas in the summer I was running through a fresh tank a week.
Since it's been cooler, I've only had the tractor out for 10 minutes at a time and haven't noticed a problem so far this winter.
Bio diesel might help but I haven't found any locally.
I've considered mods on my exhaust but with the type of work I've done I'm sure that 30% of my time has been in reverse, so it would have to go up, not back, to really help.
The one thing that might help is to make sure your loader arm isn't lined up perfectly with the exhaust if/when possible, so it blows further away.
Thank you all for your responses. I'm NOT absolutely sure that it is the diesel that originated the problem, and I've resisted this idea from the start. My first project was a lot of digging and stump pulling during very hot and humid weather which generated a lot of dust, and, as some have suggested, no doubt mold spores. I like the idea that that could be the trigger, not the diesel.
A CAT scan in October finally revealed that I had a massive sinus infection which was treated with antibiotics, I felt much better afterwards (I had come to realize that i had been tired all of the time which should have been a clue to infection, duh), but the nasal sound in my voice has never really cleared up all of the way. People constantly ask if I have a cold. A major contributor to the infection could have been a bathroom remodel I did with a lot of old grout dust in the air.
In early December I dug a 90' trench to lay a drain pipe under my driveway in 40 degree dampish weather so not much dust, probably 9 or 10 hours of seat time over a few days, and I got noticably worse. (So I don't think dust was a big factor this time, I actually wore a disposable dust mask for some of it as i had been doing earlier in the fall when cleaning up leaves.) Dr. scoped my nose and saw irritation but no infection. BUT, there has been hay moving, compost turning, lots of outdoor time in cold dry weather, more so this year than in years past... I really want to believe it is all of these other things and not the diesel, especially since I'm not hearing from most of you that it is a problem.
So perhaps it is only that the diesel is aggravating an already aggravated condition--one of the links I followed to farmer's lung explained how this could be the case (with lungs not sinuses).
I like the suggestion of some kind of temporary flex pipe that would carry exhaust up so I could see if it got any better. Could it be as simple as a piece of 1 1/4"flex plastic hose attached to the end of the exhaust pipe and taped to the ROPS?? Too hot?? Are there back pressure issues? Is there some kind of inexpensive flex aluminum hose like i'd use on a dryer vent only smaller diameter?
A respirator would not be much fun and wouldn't provide a good diagnosis either. Too bad there's no respirator I could put on the pipe to catch particles at the source.... I've thought about a wet sponge canister of some sort....
I feel like if I could just get this thing cleared up and then start over I could really tell what is going on. But that might involve a couple of months off of the tractor--hard to bear the thought of that.
Thanks for your input.
/ Allergic to my tractor? #27
Hi Vicar,
Sinusitus has been a problem for many years. I've had 3 separate operations in 30+ years.
This past fall was really bad in Connecticut, many people suffered. The early spring was not good either. Although the diesel smoke could be the problem, it could very well be enviromental issues, as has been noted. My problem is the earth and wood.
Well, this is my favorite pass-time! and I'm not giving it up :mad: sooo, I wear a particle mask unless it's real hot, then I use a more comfortable dust mask....:rolleyes:
Yeah I know it suks, but I take benadryl, and sudafed and use a nasal moisturizing spray, You're not alone ...:)
If an infection is real bad, I'll stop working outside for a while...gotta do what we gotta do..;)
/ Allergic to my tractor? #28
hmmmm........ bathroom remodels......... I went to my doc for a servere headache, he ordered x-rays and the x-ray technician pulled me aside and asked if I knew I had a sinus infection. I was in the midst of a bathroom remodel, the floor around the toilet was rotted and moldy. After 2 days on antibiotics (OK this part gets gross) it broke up and came out of my nose like cottage cheese :eek: Felt lots better :)
If I were you I'd try using a respirator through winter, then give it a go again next spring. Just my 2 cents.
/ Allergic to my tractor? #29
One of the things I have found to help is a neti pot. Basically you run saline solution through your nose/sinuses. It is actually not as bad as it sounds. You can buy it at Walgreens or other drugstore. I'll do it after doing something particularly dusty or when I can start to feel some pressure in my sinus. Many, many times better than saline spray. There are some videos out there on youtube that show how to use one. On occasion I have been damned impressed with how much junk comes out of my sinus.
/ Allergic to my tractor? #30
Vicar,
There's a lot of 'stuff' in the air in Connecticut, I've always suspected. I had constant sinus congestion and allergy-like symptoms my last 6 years there, and I lived there, aside from a stint in NC for 4 years, until I was 25. I was on Sudafed pills for years because if I wasn't, I was constantly congested, pretty much year round. When I finally weaned myself off of the Sudafed, I spent my last few years in CT congested and with minor headaches, but I figured that was better than putting all those drugs in my body.
As soon as I moved to Colorado, a very dry climate, my sinus issues cleared up, congestion went away, and non-stop minor headaches became a thing of the past, and haven't returned. I've developed some allergies to certain types of pollen, but that is fairly short lived in spring and fall.
I'm not saying that you should pack up and move, just that you may want to start taking some additional precautions. Since you seem to have a nagging sinus infection/irritation, you may want to use a filtering mask of some sort until the irritation is completely cleared up so that you can continue your tractor therapy. After that, you may just want to use an inexpensive dust mask - not a bad idea for all of us tractor operators considering the various types of microscopic particles we are subjected to. I don't use them religiously, but when I'm working in extremely dusty conditions, I will put one on, and at the end of the day, I'm appreciative of my good sense in using a mask.
/ Allergic to my tractor? #31
Are you using off-road diesel? Maybe it's the dye, although that would be really great luck if it were, since the solution would be just to use on-road (for another $0.30/gallon or something...)
Also, I don't really know anything about alternative fuels, but from what my dealer told me, you can safely run non-diesel fuels in your BX. What those fuels are, I don't know. But perhaps someone here has some experience or your dealer could give you some suggestions of what else you can run (and hopefully readily purchase).
/ Allergic to my tractor? #32
I once made the mistake of cutting our field of weeds without a mask. Yellow Russian Star Thistle is really toxic and I breathed a lot of it. Wound up with severe bronchitis that brought on chronic asthma. Took months to get over it. I have to wear a respirator mask anytime I cut now. Wearing that thing along with ear muffs and goggles in 112-114 degrees is a real PITA.
When I was a young all knowing teenager, I thought allergies were a figment of the immagination of hypochondriacs. Truth is, anybody can become allergic to almost anything. If you get something in your body and your immune system decides it sees that substance as a threat, it will make specific antibodies to attack it. The immune system can very easily get out of whack and those antibodies can attack you, throw you into anaphylactic shock, and kill you fast. And those antigens can range from anything found on your land, to, yes, particulate matter in diesel exhaust.
I don't have any advice other than that already given, but right now have bad ongoing asthma following a bronchial infection I had a month ago, so mainly just wanted to say I feel for 'ya. Hope things get better.
/ Allergic to my tractor? #33
Tom H:
I could not agree more. I now have chronic, lifelong, quality of life impacting conditions due to a lot of poor choices I made in the past :(. A staff person who used to work for me had this expression: "If you do not take care of your body, your body will take care of you, and it is usually not pleasant :eek:". I can attest to that saying. Everyone out there in TBNland please take care of yourselves. Jay
/ Allergic to my tractor? #34
Lots of really good suggestions but I'm still puzzled. As I mentioned early in this thread I do not generally detect exhaust smells on my BX24. If the OP is readily smelling exhaust then something is wrong IMO.
As I said I'm really sensitive to airborne allergens and smells, heck I can usually tell if someone ahead of me on the freeway is smoking in their car:eek:
So why is he smelling exhaust?
I agree it would bug the fool out of me if I was smelling it but I'm not...except for startup when it smokes more and if the wind happens to be just wrong...
Other BX24 owners pipe up- are you smelling exhaust routinely:confused:
PS- I'm a fan of the Neti Pot also...
/ Allergic to my tractor? #35
On my BX23 every now and then I catch a wiff of exhaust when mowing against the wind, other than that I don't notice it.
If it got to bothering me I'd start with making up an exhaust extension pointing down to help route the exhaust down and under the tractor. Forward motion + the floor pan would keep it down and routed underneath especially when going forward.
When working stationary, about the only direction that'll route the exhaust away much better than the stock setup would be a tall stack setup, but it wouldn't be the best when moving, especially forward.
I don't know if going with a gasoline engine powered tractor would be that more benefitial.
When I refurb'ed an old 8hp Wheel Horse a couple yrs ago I went with an exhaust stack to give it more of a tractor look and after half a summer of use I went back to routing the exhaust down and forward. The gasoline exhaust got to be very nausiateing and highly detracted from my otherwise enjoyable seat time. Now with teh exhaust routed down and to the front only the occasional wind shift blows any exhaust back towards me and it's nowhere near as bad as the stack was.
Good luck
/ Allergic to my tractor? #36
Vicar,
It seems to me that extending the exhaust stack up high would be your best bet. This stuff will somewhat hold it's shape. So you can aim it backwards when you're travelling forward, aim it forward when you're using the BH, and bend it over to get into the garage.
Here is a source for flexible metallic tubing:
  • FlexPipe.pdf
Thanks all for your replies.
It's not that i smell exhaust all of the time when on my tractor. It's more like I'm aware of it after i have quit for the day and go inside. I foolishly overexposed myself to paint stripper 20+ years ago and have become more and more sensitive to all kinds of stuff as i have gotten older.
Thanks for the link to the flex pipe. Extending the pipe up would probably not work well for me as i keep having problems with unseen low hanging branches and slanted trees which seem to grow out of nowhere. But aiming the exhaust more downward under the tractor is an interesting alternative. At the least it might help me sort out if it is the diesel fumes or something else.
Having heard that this is not a problem most others experience has been reassuring. A forwarded link to diesel related illnesses didn't even mention sinus irritation but rather lung problems as the common symptom. Somehow that was reassuring too.
My currrent thinking in light of this discussion is that at worst the diesel is just aggravating something that had another cause--mold, dust, stuff in the air, etc. So i think that what i will do is to be very careful of any further irritation until this can get cleared up. Minimize tractor use, and wear a mask whenever I possibly can. Hopefully if I can get back to a healthy state, the diesel won't cause me issues. I guess it will just take me longer to get back to healthy than I had hoped. Thanks to whoever suggested the neti pot too. I've been wondering about that. I guess I'll have to try it. Whatever it takes to keep me on that machine.
Many thanks.
John
/ Allergic to my tractor? #38
Just because one is not able to smell exhaust does not mean that he is not inhaling the exhaust. After the engine warms up following the first few revs, the oxidation is much more complete, however, particulates and noxious gasses are still exhausted. The human nose, being one of the poorest olfactors among all animals, does not detect many things in the air. You can breathe in many allergins and not smell them. Not being able to detect them with the olfactory receptors does not mean that they will not trigger an auto-immune allergic response.
Now, that being said, if an odor is detectable after the block is warm, that would indicate that considerably incomplete oxidation is ocurring and that the engine needs to be checked in the shop.
/ Allergic to my tractor? #39
Dumb suggestion: Try coating the inside of your nose with Vaseline before you start. I have used Vaseline inside my nose to help with dry nasal passages and it seems to help.
At least it would coat your nasal passages and maybe keep some of the "stuff" from coming in direct contact.
I would think blowing your nose every 15 to 30 minutes might help to clear out the offensive stuff.
I use saline nasal spray and it helps wash out any irritants. Spray a LOT of saline spray, wait a few seconds, blow.
1995 Skeeter 300ZX Bass Boat (A65579)
1995 Skeeter 300ZX...
Round Bale Livestock Feeder (A66408)
Round Bale...
2025 Mower King SSVR72 Hydraulic Vibratory Roller Skid Steer Attachment (A64553)
2025 Mower King...
CATERPILLAR D4H CRAWLER DOZER (A64277)
CATERPILLAR D4H...
KUBOTA SVL97-2 SKID STEER (A65053)
KUBOTA SVL97-2...
(1) 235/80R16 TIRE W/ (8) LUG WHEEL (A64280)
(1) 235/80R16 TIRE...
